Picante1 0 Posted October 28, 2021 Posted October 28, 2021 Hi, I have been able to figure out that there is a convert feature that can be enabled for a specific TV Series or a Movie, but is there a way to do this at a Library level? Thanks.
Solution Luke 42197 Posted October 28, 2021 Solution Posted October 28, 2021 Hi, yes the three dot context menu has this option available at the library level.
Picante1 0 Posted October 29, 2021 Author Posted October 29, 2021 Great, thanks!!!, I found it, I was looking under Settings-->Server-->Library. Just in case someone else is stuck. I found it rom the left menu, Selected Home, then under my Media, each one of the Tv Series and Movie libraries had the options.
