atgomez6555 0 Posted October 28, 2021 Posted October 28, 2021 Hello, The normal top bar which contains profile button and Home/Favorite toggle is not present, and there is a second bottom bar super imposed on top. If I tap where the profile button is supposed to be, I can still access it. The background is very transparent too compared to normal. Server Version: 4.6.4.0 Didn't see any logs under /Android/data/com.mb.android/files/logs
atgomez6555 0 Posted October 28, 2021 Author Posted October 28, 2021 Hello, The web app looks as expected.
Luke 42243 Posted October 28, 2021 Posted October 28, 2021 what version of chrome do you have installed?
atgomez6555 0 Posted October 28, 2021 Author Posted October 28, 2021 The web screenshot was Firefox 93.2.0 Chrome also looks fine, which is 94.0.4606.85
Luke 42243 Posted October 28, 2021 Posted October 28, 2021 OK, well somewhat good news to report. I don't see the same issue on my Pixel 5, so hopefully this is not widespread. Do you have any system updates available by chance? Have you customized any system or display settings that could impact this? I'm testing on mostly default OS settings, other than enabling gesture navigation. I don't have a Pixel 6 yet but I will within the next couple weeks, so I'll be able to try on that then.
atgomez6555 0 Posted October 28, 2021 Author Posted October 28, 2021 (edited) Under display settings: Font size large When put back to default I can now see the top menu. But when scrolling down I still get the superimposed bottom bar under the status bar at top. Edited October 28, 2021 by atgomez6555
atgomez6555 0 Posted October 28, 2021 Author Posted October 28, 2021 My previous phone is a OnePlus 7 Pro and I have large font size on there with no issue, but it is running Android 11 with obviously the OnePlus skin on top.
dasrhombus 0 Posted November 1, 2021 Posted November 1, 2021 I'm having the same issue on the Pixel 6 Pro. My font size is set to the default. I've cleared all cache and data but it persists. I've also noticed the "Save button is missing and replaced by another "Cancel" button. This happens when logging in or trying to create a new user, etc.
Luke 42243 Posted November 1, 2021 Posted November 1, 2021 Very odd. I'll have a Pixel 6 within the next two weeks so hopefully I'll be able to reproduce. Thanks.
seanbuff 1356 Posted November 2, 2021 Posted November 2, 2021 Just chiming in with my experience running a Pixel 6 (non-Pro version) against a Pixel 5, both running the latest Android 12 version. I'm thinking because of the smaller screen size from the Pro, I am not seeing the duplicate bottom menu at the top of the screen, but I am seeing: Duplicate 'Cancel' button on screens where a cancel button exists, eg. New User, Live TV setup, etc. Super opaque overlays, seen in the popup and also top bar I will report any other oddities I may come across.
my95z34 4 Posted November 6, 2021 Posted November 6, 2021 (edited) Just to chime in. Same issues on my 6 Pro. Font size small, display size small. Willing to provide any logs or do any testing as requested. Thanks! Edited November 6, 2021 by my95z34
gbolton2008 0 Posted November 6, 2021 Posted November 6, 2021 Same here, pixel 6 pro having all the issues mentioned above. Worth noting is that quite similar display issues are also seen with the Home Assistant app
Milldor 14 Posted November 12, 2021 Posted November 12, 2021 Whenever I have music playing and return to the home screen the now playing info shows at the top and bottom of the screen. Is this a feature or a "feature"?
gillmacca01 220 Posted November 12, 2021 Posted November 12, 2021 Never seen this at the top. is this through the android app or browser?
seanbuff 1356 Posted November 12, 2021 Posted November 12, 2021 Looks like the Pixel issue. Is that a new Pixel 6 Pro?
seanbuff 1356 Posted November 12, 2021 Posted November 12, 2021 https://emby.media/community/index.php?/topic/102945-pixel-6-pro-android-12-not-displaying-right/
Milldor 14 Posted November 12, 2021 Posted November 12, 2021 1 hour ago, seanbuff said: Looks like the Pixel issue. Is that a new Pixel 6 Pro? Is a 6, yeah.
Luke 42243 Posted November 16, 2021 Posted November 16, 2021 OK, testing on my Pixel 6, I can reproduce. My initial suspicion turned out to be true. It is a platform rendering defect and we can work around it by disabling the blur background effect that is used in many parts of the app. I'll only disable it just for these two devices, or perhaps the whole chipset if we can detect that. This way it won't be lost on other devices. I'll periodically try to re-enable it and see if it can be used again. Thanks. 2
gbolton2008 0 Posted November 16, 2021 Posted November 16, 2021 It isn't just the Emby app that behaves like this, I've seen similar behaviour in the home assistant app too, intermittently.
Luke 42243 Posted November 16, 2021 Posted November 16, 2021 3 minutes ago, gbolton2008 said: It isn't just the Emby app that behaves like this, I've seen similar behaviour in the home assistant app too, intermittently. Yea I think they have issues that need addressing in either Chromium or the android WebView. 1
Luke 42243 Posted November 20, 2021 Posted November 20, 2021 I'll be pushing an update to the beta channel in the store within the next day or so, but for immediate resolution you can grab the build from our website: https://emby.media/emby-for-android.html Thanks. 1 1
atgomez6555 0 Posted November 20, 2021 Author Posted November 20, 2021 10 minutes ago, Luke said: I'll be pushing an update to the beta channel in the store within the next day or so, but for immediate resolution you can grab the build from our website: https://emby.media/emby-for-android.html Thanks. Downloading the apk fixed the issue for me. Will future updates from the play store download fine?
Luke 42243 Posted November 20, 2021 Posted November 20, 2021 3 minutes ago, atgomez6555 said: Downloading the apk fixed the issue for me. Will future updates from the play store download fine? Yes.
