BigIrn 10 Posted March 15, 2025 Posted March 15, 2025 4 minutes ago, sundevil67 said: I have it M3UtoSTRM (from the catalog) installed; just not working for me. It just creates empty directories & copies of my m3u files. I was just looking at the "Beta" one by @mickle026& looks like it may just be more than I can chew. I think this may just be something I have to do without. I appreciate the help. I promise it seems daunting but it's easy peasy once you get it going. Copy paste the plugin @mickle026created into 3 folders and point your m3u in the plugin ui, rip and run
Luke 42239 Posted September 7, 2025 Posted September 7, 2025 You also have more tools at your disposal now using the new webstreams plugin:
sundevil67 30 Posted September 8, 2025 Posted September 8, 2025 On 3/15/2025 at 10:56 AM, BigIrn said: I promise it seems daunting but it's easy peasy once you get it going. Copy paste the plugin @mickle026created into 3 folders and point your m3u in the plugin ui, rip and run I got it working the first time, switched to movies, it worked, back to TV to try and get it to just keep automatically updating and pulling in recent episodes, and now it quits after a few seconds again..Still messing with it.
sundevil67 30 Posted September 8, 2025 Posted September 8, 2025 On 9/7/2025 at 11:30 AM, Luke said: You also have more tools at your disposal now using the new webstreams plugin: Thanks! Although I'm not seeing it yet because I'm not on that version, like you said...though my dashboard says I'm up to date for MacOS Server (Version 4.8.11.0), so that's probably why it's not coming up for me in the plugin catalog. 1
sundevil67 30 Posted September 9, 2025 Posted September 9, 2025 22 hours ago, sundevil67 said: I got it working the first time, switched to movies, it worked, back to TV to try and get it to just keep automatically updating and pulling in recent episodes, and now it quits after a few seconds again..Still messing with it. My problem now is the update - it lists a slew these in the log: "09.Sep.2025 - 00:28:26 Item does not exist in Emby library", and at the end it says "09.Sep.2025 - 00:28:42 Library update failed: Unauthorized". I'm trying to look for new episodes after the initial download, but can't figure out why it'd be unauthorized all of a sudden...
