alameri39 2 Posted October 27, 2021 Posted October 27, 2021 hello emby Community When activating ssl in cloudflare lose contact with emby server Is there any solution?
Abobader 3485 Posted October 27, 2021 Posted October 27, 2021 Hello alameri39, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
alameri39 2 Posted October 27, 2021 Author Posted October 27, 2021 (edited) What happened? The initial connection between Cloudflare's network and the origin web server timed out. As a result, the web page can not be displayed. What can I do? If you're a visitor of this website: Please try again in a few minutes. If you're the owner of this website: Contact your hosting provider letting them know your web server is not completing requests. An Error 522 means that the request was able to connect to your web server, but that the request didn't finish. The most likely cause is that something on your server is hogging resources. Additional troubleshooting information here Edited October 27, 2021 by Happy2Play Removed images
Luke 42197 Posted October 27, 2021 Posted October 27, 2021 Hi there, what do you mean by lose contact? 1
alameri39 2 Posted October 27, 2021 Author Posted October 27, 2021 Are the settings correct or do I have ssl ?
alameri39 2 Posted October 27, 2021 Author Posted October 27, 2021 (edited) 1 hour ago, Luke said: Hi there, what do you mean by lose contact? When I connect without cloudflare protection it works fine with my domain bstaie.co If you enable https, it does not work Edited October 27, 2021 by alameri39
Solution Carlo 4561 Posted October 27, 2021 Solution Posted October 27, 2021 Hi, you want FULL not flexible for the SSL/TLS mode. You then need to download the cert information to use in order to establish that connection. Do you have a local reverse proxy installed? If not you need to use port 443 for the public port number for HTTPS in Emby Server with port 443 open on your router forwarded to the Emby Server IP and port 8920. 443->8920 You then need to convert the cert information you get from Cloudflare to PKCS #12 format and set a password. Add both the path to the PKCS #12 cert file in Emby Network settings along with entering the password. Set Secure connection mode: to Required. Sounds like a lot but not that hard when you break it down into the individual steps. If you get stuck, let us know and we can assist. 1
alameri39 2 Posted October 27, 2021 Author Posted October 27, 2021 (edited) It's already working it's magic I gave a lifetime service, I tried for 3 days in a row and here I found the solution Thank you very much for the interesting explanation 1 hour ago, cayars said: Hi, you want FULL not flexible for the SSL/TLS mode. You then need to download the cert information to use in order to establish that connection. Do you have a local reverse proxy installed? If not you need to use port 443 for the public port number for HTTPS in Emby Server with port 443 open on your router forwarded to the Emby Server IP and port 8920. 443->8920 You then need to convert the cert information you get from Cloudflare to PKCS #12 format and set a password. Add both the path to the PKCS #12 cert file in Emby Network settings along with entering the password. Set Secure connection mode: to Required. Sounds like a lot but not that hard when you break it down into the individual steps. If you get stuck, let us know and we can assist. In my case I have use port 2096 as the external port https I have port control Edited October 27, 2021 by alameri39 1
alameri39 2 Posted October 27, 2021 Author Posted October 27, 2021 Can you hide pictures because the server information is personal ? @cayars @Luke
Carlo 4561 Posted October 27, 2021 Posted October 27, 2021 I can't do it or I would for you. A mod or admin needs to do it. You can click the 3 dot menu and report a problem for those posts. Just ask to have the pics removed.
Happy2Play 9802 Posted October 27, 2021 Posted October 27, 2021 3 hours ago, alameri39 said: Can you hide pictures because the server information is personal ? @cayars @Luke removed images and error with domain name.
alameri39 2 Posted October 28, 2021 Author Posted October 28, 2021 6 hours ago, Luke said: Are you all set now? Yas thank you for help 1
