Replacement of dependency will break Emby beta
Locutus64
I'm running Manjaro testing and there are updates for it to day and when I go to install them I get the below. I would like to know since I won't lose my settings or libraries if I can just uninstall the Emby beta, do the updates and then reinstall Emby?
   ~  sudo pacman -Syu         ✔
[sudo] password for locutus:
:: Synchronizing package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur                               1569.2 KiB  2.20 MiB/s 00:01 [########################################] 100%
herecura is up to date
:: Starting full system upgrade...
warning: gsettings-desktop-schemas: local (41.0-1) is newer than extra (40.0-3)
:: Replace python-sgmllib with extra/python-sgmllib3k? [Y/n] y
resolving dependencies...
looking for conflicting packages...
error: failed to prepare transaction (could not satisfy dependencies)
:: installing x264 (3:0.163.r3060.5db6aa6-1) breaks dependency 'libx264.so=161-64' required by emby-server-beta
https://forum.manjaro.org/t/replace-python-sgmllib-with-extra-python-sgmllib3k-failed-to-prepare-transaction/88131/7
Edited by Locutus64
escapereality
I replied the following to your question at the AUR comment session.
Quote
Locutus64: No you'll not lose your libraries if you do the following (copy-paste from my earlier reply to someone else):
Emby is built locally on your system, using the locally installed libx264 version. So to compile emby with libx264.so=160, ideally you should first update the x264 package (which is a hassle because of the dependency complaints).
What you should do is first temporarily remove the emby-server-beta package (pacman -R emby-server-beta), then update x264 (pacman -Syu), and finally install emby-server-beta again.
  • Like 1
Locutus64
OK cool I just replied that did the trick, so thanks again.
How are you installing the beta package?
Locutus64
either yay -S emby-server-beta or using the Pamac GUI and searching it and installing it. Which either is correct. Like I said unintaling Emby, installing the updates, and then reinstalling emby worked perfectly.
https://forum.manjaro.org/t/replace-python-sgmllib-with-extra-python-sgmllib3k-failed-to-prepare-transaction/88131/11
https://aur.archlinux.org/packages/emby-server-beta/
Edited by Locutus64
