Glassertje 4 Posted October 27, 2021 Posted October 27, 2021 Hello, I'm new to Emby and I'm busy to setup everything. But i have 1 problem. Some series episodes have no description of the episode. If i check TVDB, IMDB, thetvdb, they all have a description what the episode is about. (my English is not so good, so i hope it's readable). I tried every Episode metadata downloaders, becourse I'm assuming that is the one, but no luck. Can someone help me and tell what I'm doing wrong? Thank you.
GrimReaper 4898 Posted October 27, 2021 Posted October 27, 2021 Hey up. See below, some exact examples would be needed in order to try and identify the issue: 1
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 (edited) Thank you @GrimReaperfor your help. Sorry i missed that. I must first say, i reinstallt Emby This afternoon. I wanted to tried a fresh install on DSM7, but after install again, all settings were there. No idea how to remove all information. So i made some screenshots and serverlog. As example i took from the Power Book III: Raising Kanan (2021) E10, is the last one from season 1. But i see this also by other series. I made a screenshot of the metadata from the episode. The 2 ID's are filled in. I already tried to refresh the metadata. I added also screens of my settings from the library. I hope it is enough. embyserver.txt Edited October 27, 2021 by Glassertje Added screeshots
GrimReaper 4898 Posted October 27, 2021 Posted October 27, 2021 My guess would be that's again one of "virtual" episodes creating issues. Do you have "Display missing episodes within series" option enabled in your library settings (can't see it in your screenshot since no "Show advanced settings" ticked) ?
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 (edited) no, i did not enable it. I made a screenshot. Do you mean this? Sorry forgot to enable advanced settings. Ik make new screens and change them in the post before. Edited October 27, 2021 by Glassertje
GrimReaper 4898 Posted October 27, 2021 Posted October 27, 2021 2 minutes ago, Luke said: What exactly is the problem? No episode details (title/synopsis) scraped. 1
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 Some episodes have no discreption of the episode. I have no idea how to tell this in another way.
Luke 42243 Posted October 27, 2021 Posted October 27, 2021 2 minutes ago, Glassertje said: Some episodes have no discreption of the episode. I have no idea how to tell this in another way. That's the first time you said it, so thanks.
Luke 42243 Posted October 27, 2021 Posted October 27, 2021 Try setting the top series metadata fetcher to tvdb, then refresh metadata on the series. Please see if that helps
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 I trie again. must i disable the other2? I have them all enabeld?
GrimReaper 4898 Posted October 27, 2021 Posted October 27, 2021 1 minute ago, Luke said: That's the first time you said it, so thanks. That wouldn't be exactly correct. 1 hour ago, Glassertje said: I'm new to Emby and I'm busy to setup everything. But i have 1 problem. Some series episodes have no description of the episode.
GrimReaper 4898 Posted October 27, 2021 Posted October 27, 2021 Just now, Glassertje said: I trie again. must i disable the other2? I have them all enabeld? Just put TVDB on top.
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 (edited) Now the episode have a name, but still missing some description. So that I'm not mistaking, this is the right setting? Edit: I also tried only TVDB, but than for all series there is no story line anymore. Edited October 27, 2021 by Glassertje
Luke 42243 Posted October 27, 2021 Posted October 27, 2021 Did you check what data tvdb has in your chosen metadata language?
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 (edited) Yes. Another serie is The Blacklist Season 9 Episode 1, is empty to. On the TVDV there is a description. Maybe i do something wrong. Edited October 27, 2021 by Glassertje
Luke 42243 Posted October 27, 2021 Posted October 27, 2021 What is your configured metadata language?
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 dutch, but series that don't have dutch there is English description automatically. I tried also leave it blank.
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 (edited) I just changed the metadata of the episode that have no description to English and United Stated and now i see the description. The strange thing is, that the other 9 episodes have English description to, whiteout changing anything. Edit: i did the same whit The Blacklist S9e1 and that did not work. Edited October 27, 2021 by Glassertje 1
Glassertje 4 Posted October 27, 2021 Author Posted October 27, 2021 (edited) Now, the blacklist have a description too. Thank you for the help. Is there a way that if there is no dutch translation that English will be downloaded. This happens already by allot of series but some not by default. Edited October 27, 2021 by Glassertje
