jdazzle44 7 Posted October 26, 2021 Posted October 26, 2021 I have been trying to get tone mapping working for the last few days but no luck. I have attached my settings, the log file and a picture from the movie showing the washed out 1080p transcode vs 4k direct. Another note is that VAAPI does not work for me. ffmpeg-transcode-96918826-b174-469a-815d-71e517107849_1.txt
Luke 42246 Posted October 27, 2021 Posted October 27, 2021 Hi there, why do you think it's not working?
jdazzle44 7 Posted October 27, 2021 Author Posted October 27, 2021 2 hours ago, Luke said: Hi there, why do you think it's not working? The colors looks washed out compared to the 4k version.
Touz604 11 Posted October 27, 2021 Posted October 27, 2021 I'm interested also in this, I had similar results regarding the tone mapping part when I was testing it last week. I don't know if the example screenshots are representative of the expected output of the tone mapping functionality.
jdazzle44 7 Posted October 31, 2021 Author Posted October 31, 2021 On 10/27/2021 at 2:12 PM, Touz604 said: I'm interested also in this, I had similar results regarding the tone mapping part when I was testing it last week. I don't know if the example screenshots are representative of the expected output of the tone mapping functionality. I gave up on it and decided to keep HD version of my movies instead.
Solution softworkz 5133 Posted November 14, 2021 Solution Posted November 14, 2021 On 10/27/2021 at 6:53 PM, jdazzle44 said: On 10/27/2021 at 4:37 PM, Luke said: Hi there, why do you think it's not working? The colors looks washed out compared to the 4k version. Your log indicates that tone mapping is happening. You can install the "Diagnostics Plugin" from the plugin catalog to configure tone mapping parameters (the default settings are not always the best choice).
Luke 42246 Posted November 21, 2021 Posted November 21, 2021 @jdazzle44 have your questions been answered?
