bandit8623 226 Posted October 26, 2021 Author Posted October 26, 2021 2 minutes ago, Luke said: We haven't added that ability yet to that app, so until that happens your ssl certificate has to be something the device trusts. so is there away around besides turning off https or having them sideload?
bandit8623 226 Posted October 26, 2021 Author Posted October 26, 2021 3 hours ago, Luke said: Using another certificate. Hopefully a bulletin gets put up that you can't use no-ip a for ssl.. I wouldn't have gone through this all to find this out after the fact...
bandit8623 226 Posted October 30, 2021 Author Posted October 30, 2021 On 10/25/2021 at 9:24 PM, Luke said: We haven't added that ability yet to that app, so until that happens your ssl certificate has to be something the device trusts. can i ask if this is in the works? thanks
ebr 16337 Posted October 30, 2021 Posted October 30, 2021 5 hours ago, bandit8623 said: can i ask if this is in the works? It is in our plans but, ultimately, a trusted certificate is the best solution. There are couple of topics out here recently on how to update the certificate on the server.
bandit8623 226 Posted October 30, 2021 Author Posted October 30, 2021 (edited) 5 hours ago, ebr said: It is in our plans but, ultimately, a trusted certificate is the best solution. There are couple of topics out here recently on how to update the certificate on the server. My cert is trusted.. just apparently not by Amazon... All other devices don't get the popup saying to trust. They just work. So it seems to be an Amazon problem Edited October 30, 2021 by bandit8623
pwhodges 2033 Posted October 30, 2021 Posted October 30, 2021 It's not the certificate itself, it's a matter of the root certificate in the client that is used to verify it. If that root certificate is out of date, then there will be a failure. Specific devices may have out-of-date roots while others are OK - a recent thread discussed LetsEncrypt certs failing on some LG televisions for the same reason. Paul
bandit8623 226 Posted October 31, 2021 Author Posted October 31, 2021 4 hours ago, pwhodges said: It's not the certificate itself, it's a matter of the root certificate in the client that is used to verify it. If that root certificate is out of date, then there will be a failure. Specific devices may have out-of-date roots while others are OK - a recent thread discussed LetsEncrypt certs failing on some LG televisions for the same reason. Paul Thx Paul.
bandit8623 226 Posted October 31, 2021 Author Posted October 31, 2021 well sideloaded the latest app on my firestick today and the keyboard will not pop up to enter any info. rebooted reinstalled... nothing. was over at a family members house today and tried their firestick and no keyboard when using the sideloaded app... the sideloaded app last week worked, so something is up with an update?
rbjtech 5344 Posted November 3, 2021 Posted November 3, 2021 Hi - So I had another go at connecting - and it is 100% a Trust issue with that cert. I used the Amazon Silk browser on my FireTV to connect and I get the Cert Authority Not Trusted message - If I confirm it, then I can connect - you'll see the attempts in your log. So in summary for FireTV usage, you can either 1) change your TLS/Cert provider 2) Possibly use Amazon Silk (not a good user experience!) or 3) Wait for Emby to add the option in the FireTV App to accept the unsupported cert. I'd suggest going with #1 - as having a Trust issue on your cert may lead to all sort of other issues in time. FYI - Amazon has no issues with Let's Encrypt as a CA on a Gen 2 FireTV.
bandit8623 226 Posted November 3, 2021 Author Posted November 3, 2021 (edited) 2 hours ago, rbjtech said: Hi - So I had another go at connecting - and it is 100% a Trust issue with that cert. I used the Amazon Silk browser on my FireTV to connect and I get the Cert Authority Not Trusted message - If I confirm it, then I can connect - you'll see the attempts in your log. So in summary for FireTV usage, you can either 1) change your TLS/Cert provider 2) Possibly use Amazon Silk (not a good user experience!) or 3) Wait for Emby to add the option in the FireTV App to accept the unsupported cert. I'd suggest going with #1 - as having a Trust issue on your cert may lead to all sort of other issues in time. FYI - Amazon has no issues with Let's Encrypt as a CA on a Gen 2 FireTV. option 1 isnt a good option as ive already set it up and its working on everything but fire sticks. second there is no way to know if other certs could have a problem down the road... really sad that the fire tv app just doesnt have the option to accept a cert... i appreciate the help.. just seems silly to be limited to letsencrypt Edited November 3, 2021 by bandit8623
rbjtech 5344 Posted November 3, 2021 Posted November 3, 2021 (edited) 11 minutes ago, bandit8623 said: i appreciate the help.. just seems silly to be limited to letsencrypt No I was just saying that letsencrypt is fine as they had a large change earlier last month that took out a few devices, but FireTV was not one of them - I've not heard of any FireTV cert issues, except yours unfortunately .. Edited November 3, 2021 by rbjtech
ebr 16337 Posted November 3, 2021 Posted November 3, 2021 37 minutes ago, bandit8623 said: option 1 isnt a good option as ive already set it up and its working on everything but fire sticks I disagree in that correcting the certificate is definitely the best option going forward as there is no telling what other issues may crop up in the future from this. We will eventually get the ability to accept untrusted certs in the app but getting a proper trusted cert is still the best thing to do to avoid possible future issues. 1
bandit8623 226 Posted November 3, 2021 Author Posted November 3, 2021 (edited) 33 minutes ago, ebr said: I disagree in that correcting the certificate is definitely the best option going forward as there is no telling what other issues may crop up in the future from this. We will eventually get the ability to accept untrusted certs in the app but getting a proper trusted cert is still the best thing to do to avoid possible future issues. but its not my certs problem is the fire sticks. no other devices give any warning about a bad cert (chrome, firefox, opera, ). how is it no-ips fault if amazon doesnt trust it? Edited November 3, 2021 by bandit8623
Luke 42245 Posted November 3, 2021 Posted November 3, 2021 36 minutes ago, bandit8623 said: but its not my certs problem is the fire sticks. no other devices give any warning about a bad cert (chrome, firefox, opera, ). how is it no-ips fault if amazon doesnt trust it? It's not about whose fault it is. On amazon devices, we have to play by amazon's rules, and they can choose the certificates they want to trust as they please.
bandit8623 226 Posted November 3, 2021 Author Posted November 3, 2021 (edited) 29 minutes ago, Luke said: It's not about whose fault it is. On amazon devices, we have to play by amazon's rules, and they can choose the certificates they want to trust as they please. Right.. and so shouldn't it be a priority to update the app to let us allow the cert? Fixed everyone's issues across the board Edited November 3, 2021 by bandit8623
ebr 16337 Posted November 3, 2021 Posted November 3, 2021 1 hour ago, bandit8623 said: but its not my certs problem is the fire sticks Not exactly as an intermediate of your certificate is expired. Correcting that will correct the problem on the Fire and any other device that also would not trust that expired cert. For now, you can use the standard Android app to get around this if desired.
bandit8623 226 Posted November 3, 2021 Author Posted November 3, 2021 19 minutes ago, ebr said: Not exactly as an intermediate of your certificate is expired. Correcting that will correct the problem on the Fire and any other device that also would not trust that expired cert. For now, you can use the standard Android app to get around this if desired. i cant as the keyboard wont pop up on the apk as of 3 days ago. i havent heard back if its fixed
Luke 42245 Posted November 3, 2021 Posted November 3, 2021 2 hours ago, bandit8623 said: i cant as the keyboard wont pop up on the apk as of 3 days ago. i havent heard back if its fixed I've updated the build on our website to resolve this. Thanks.
siu99ss2 13 Posted November 3, 2021 Posted November 3, 2021 Hi, I am having similar issues as OP. I have a No-IP SSL cert as it was simply easier to setup than other options as I also have their Ddns service. Plus my knowledge of computers and networking is very limited so a single provider seemed the best choice. I only realised why my FTV stick wasn’t connecting because of this thread - thanks OP for highlighting this issue I understand that it’s not the fault of Emby or the team but is there a list of SSL providers available which are recommended with Emby apps on devices like FireTV, AppleTV, Roku, etc? Or will a fix be available soon? Many thanks
Luke 42245 Posted November 3, 2021 Posted November 3, 2021 20 minutes ago, siu99ss2 said: Hi, I am having similar issues as OP. I have a No-IP SSL cert as it was simply easier to setup than other options as I also have their Ddns service. Plus my knowledge of computers and networking is very limited so a single provider seemed the best choice. I only realised why my FTV stick wasn’t connecting because of this thread - thanks OP for highlighting this issue I understand that it’s not the fault of Emby or the team but is there a list of SSL providers available which are recommended with Emby apps on devices like FireTV, AppleTV, Roku, etc? Or will a fix be available soon? Many thanks In this app there is the possibility to add a user override to force the device to accept it. On other platforms such as Roku this isn't' possible, so you'll want to look into what Roku accepts. Please note that for android, if you need immediate resolution you can sideload our standard android app on the same device: https://emby.media/emby-for-android.html
bandit8623 226 Posted November 3, 2021 Author Posted November 3, 2021 1 hour ago, Luke said: I've updated the build on our website to resolve this. Thanks. Thank you Luke!
siu99ss2 13 Posted November 4, 2021 Posted November 4, 2021 Thanks Luke. I've just tested my No-IP certificate (TrustCor) on the current Amazon FireTV Cube (2nd Gen) and it connects to my server without any issues, so this is not a problem for me anymore. I think the AFTV Cube has Android v9 which must include the necessary signing certs.
bandit8623 226 Posted November 5, 2021 Author Posted November 5, 2021 (edited) 9 hours ago, siu99ss2 said: Thanks Luke. I've just tested my No-IP certificate (TrustCor) on the current Amazon FireTV Cube (2nd Gen) and it connects to my server without any issues, so this is not a problem for me anymore. I think the AFTV Cube has Android v9 which must include the necessary signing certs. I did put in a ticket with no-ip last week maybe it actually went somewhere? I'll do some more testing this weekend when I get time on my fire stick 4k Edited November 5, 2021 by bandit8623 1
Luke 42245 Posted November 5, 2021 Posted November 5, 2021 2 minutes ago, bandit8623 said: I did put in a ticket with no-ip last week maybe it actually went somewhere? I'll do some more testing this weekend when I get time on my fire stick 4k Let us know how you get on. Thanks.
