mirdragon 15 Posted October 23, 2021 Posted October 23, 2021 I can rescan the channels in HDHR app and Plex, but where is the option within Emby to rescan the channels on the HDHR tuners. Do you need to remove and re-add the turners again for the changes to be picked up?
Carlo 4561 Posted October 24, 2021 Posted October 24, 2021 Hi, When you you do a guide refresh is it not picking up any new channels or removing channels?
mirdragon 15 Posted October 24, 2021 Author Posted October 24, 2021 i'm asking about rescanning of the tuner for the available channels, not the guide if i rescan the channels using HDHR does Emby pick them up when the guide is updated If I don't use HDHR to scan for channels (for change in frequencies or numbering) how can you tell Emby to rescan all available frequencies for channels
Carlo 4561 Posted October 24, 2021 Posted October 24, 2021 I understand what you're asking. It should happen automatically with a guide update. That's why I was asking if you refresh the guide does it it pickup the changes to the tuner. Sorry I was not more clear previously on this. 1
mirdragon 15 Posted October 24, 2021 Author Posted October 24, 2021 Yes when the guide refreshes it updates the channel list, which I assume it gets the list from the HDHR and only looks at the ones I've enabled
justinrh 267 Posted October 24, 2021 Posted October 24, 2021 @mirdragon So, does this mean you picked up the missing channel and everything is good now? I did a guide refresh and I'm still not picking up the new channel.
Luke 42243 Posted October 24, 2021 Posted October 24, 2021 2 hours ago, mirdragon said: Yes when the guide refreshes it updates the channel list, which I assume it gets the list from the HDHR and only looks at the ones I've enabled This is correct, yes. 1
Carlo 4561 Posted October 25, 2021 Posted October 25, 2021 6 hours ago, justinrh said: @mirdragon So, does this mean you picked up the missing channel and everything is good now? I did a guide refresh and I'm still not picking up the new channel. Can you go over this with a specific example?
justinrh 267 Posted October 25, 2021 Posted October 25, 2021 I picked up 54.6 but not getting guide data. (That channel was a surprise to me.) I'm supposed be getting 38.8 but I'm not. No guide data for 54.5 or 54.6 in Huntsville, AL, 35810.
justinrh 267 Posted October 26, 2021 Posted October 26, 2021 (edited) Those two channels say 'not mapped to guide data'. I edited the channel to use Emby guide data, but it doesn't persist, and there is no channel in the 'guide data channel' list. What does this mean? How could the channel be in the list and not have any guide data? And this is weird - 67.2 is in the master list, but not in the data channel list, and vice versa for 67.1. Edited October 26, 2021 by justinrh
justinrh 267 Posted October 26, 2021 Posted October 26, 2021 Sorry to hijack this thread. I created a post in the guide forum for resolution.
Carlo 4561 Posted October 27, 2021 Posted October 27, 2021 I see the message in the guide section and will send this info to our provider. 1
