georgewill76 14 Posted September 8, 2014 Posted September 8, 2014 Hi Not sure if I am putting this in the right section. I have the latest version of MB Server and MC Classic. For MBC I am using the Chocolate Theme. Within MB Server I have installed the Auto Boxset Plugin so that it searches through my movies and puts collections/box sets together. On previous versions of Server and Classic I was able to view Collections on MBC EHS Screen. Now with the latest versions of both apps I can no longer view Collections as a spate item on EHS Screen. I can view Box Sets/Collections if I choose to vie them in All Movies by enabling option in config but would rather have it separate as an EHS item. Do you know if the above will be added back soon? I can see Collections as a separate item on Web Client but not MBC.
Logos302 86 Posted September 8, 2014 Posted September 8, 2014 hmm, it never left. So I'm pretty sure it just a settings, but for the life of me I'm not sure which one it is.
Solution ebr 16334 Posted September 8, 2014 Solution Posted September 8, 2014 In the web client: User Icon -> My Preferences -> Show a Collections view to show Movie Collections
georgewill76 14 Posted September 8, 2014 Author Posted September 8, 2014 Hi Ebr Thanks for the info. Have it working now.
