Scott310 137 Posted October 22, 2021 Posted October 22, 2021 This has probably been asked before and if so I apologize. Is there any way to sideload Emby theater onto a fire cube? I love the experience of Emby theater. Also if it can be sideloaded would that mean I would get my video backdrops back?
GrimReaper 4898 Posted October 22, 2021 Posted October 22, 2021 Sideload vanilla Android app. https://emby.media/emby-for-android.html
Scott310 137 Posted October 22, 2021 Author Posted October 22, 2021 Do you know if it displays video backdrops?
GrimReaper 4898 Posted October 22, 2021 Posted October 22, 2021 1 minute ago, Scott310 said: Do you know if it displays video backdrops? Nope, as I don't fancy those, never tested.
FrostByte 5454 Posted October 22, 2021 Posted October 22, 2021 Is this what you're looking for? I never use the option myself. 1
Scott310 137 Posted October 22, 2021 Author Posted October 22, 2021 (edited) 27 minutes ago, FrostByte said: Is this what you're looking for? I never use the option myself. No I was referring to the theme videos if they would work on fire cube with a sideloaded emby theater. I'm thinking its not possible. I love Emby theater for Xbox. It has everything I want including all the manage server options like changing images and such. Edited October 22, 2021 by Scott310
GrimReaper 4898 Posted October 22, 2021 Posted October 22, 2021 So, sideload and check, shouldn't take more than few minutes?
FrostByte 5454 Posted October 22, 2021 Posted October 22, 2021 Ahh, but isn't that what the "Enable theme videos" option does at the bottom of my pic? Maybe not. Pretty much the app looks exactly like the one on the Xbox. I would just give it a whirl and see as I only use theme music. 1
Luke 42245 Posted October 22, 2021 Posted October 22, 2021 2 hours ago, Scott310 said: Do you know if it displays video backdrops? I think as of now it will play them on top of the UI, which is obviously not good. However, compared to the dedicated Android TV app, this can be supported much more easily, so I'll put it on the to do list. Thanks.
Scott310 137 Posted November 6, 2021 Author Posted November 6, 2021 (edited) Thanks @Luke . It would be great to be able to have the theater experience available on the fire cube for those that choose to sideload it. Plus video backdrops would be very pleasing. I would love to open the same or similar emby theater that I see on my Xbox on my fire cube in another room even if I have to sideload it and get video backdrops. Thanks for adding this to your to do list!!! Should I check back to this thread for updates? Edited November 6, 2021 by Scott310
Luke 42245 Posted November 7, 2021 Posted November 7, 2021 2 hours ago, Scott310 said: Thanks @Luke . It would be great to be able to have the theater experience available on the fire cube for those that choose to sideload it. Plus video backdrops would be very pleasing. I would love to open the same or similar emby theater that I see on my Xbox on my fire cube in another room even if I have to sideload it and get video backdrops. Thanks for adding this to your to do list!!! Should I check back to this thread for updates? Yes, that would be fine. Thanks.
