Painkiller88 250 Posted August 23, 2024 Posted August 23, 2024 Hi, i actually saw emby is now available in german as a skill so i installed it, linked it and it told me linked successfully. But when i try to ask to do or start anything all i get is "i am having touble to access your emby skill" so i am linked but it seems i can't do anything. I have linked my account, i linked emby connect, my server is reachable from outside etc. is there something else i need to do? Thanks
Luke 42239 Posted August 23, 2024 Posted August 23, 2024 3 hours ago, Painkiller8818 said: Hi, i actually saw emby is now available in german as a skill so i installed it, linked it and it told me linked successfully. But when i try to ask to do or start anything all i get is "i am having touble to access your emby skill" so i am linked but it seems i can't do anything. I have linked my account, i linked emby connect, my server is reachable from outside etc. is there something else i need to do? Thanks Hi, what exactly are you saying to it?
Painkiller88 250 Posted August 23, 2024 Posted August 23, 2024 31 minutes ago, Luke said: Hi, what exactly are you saying to it? "alexa say emby home play songs from XY" but i say it in german of course. It is recorgnizing what i want as it says it having trouble to access the emby skill and not trying to play it with amazon or anything else, so i think it understands what i want
Luke 42239 Posted August 24, 2024 Posted August 24, 2024 On 8/23/2024 at 12:53 PM, Painkiller8818 said: "alexa say emby home play songs from XY" but i say it in german of course. It is recorgnizing what i want as it says it having trouble to access the emby skill and not trying to play it with amazon or anything else, so i think it understands what i want Can you please give a specific example? Thanks.
Painkiller88 250 Posted August 24, 2024 Posted August 24, 2024 1 hour ago, Luke said: Can you please give a specific example? Thanks. i say for example: "Alexa sag emby zuhause spiel lieder von XY"
Painkiller88 250 Posted August 25, 2024 Posted August 25, 2024 10 hours ago, Luke said: What is XY? just random for a bandname
Roodee 39 Posted August 25, 2024 Posted August 25, 2024 funny enough, there is a band named XY https://en.wikipedia.org/wiki/XY_(band)
Luke 42239 Posted August 25, 2024 Posted August 25, 2024 12 hours ago, Painkiller8818 said: just random for a bandname Can you try saying it slowly and loudly?
Painkiller88 250 Posted August 25, 2024 Posted August 25, 2024 (edited) 2 hours ago, Luke said: Can you try saying it slowly and loudly? the result is the same, "i'm having problems to access your emby skill" It does not say it does not understand me My server is not using 443 as the Secure Port, i use the normal emby ports. So is there anything else i need to open except the normal ports? Does the skill require a special port? Thanks Edited August 25, 2024 by Painkiller8818
hatharry 113 Posted August 27, 2024 Posted August 27, 2024 On 8/26/2024 at 9:23 AM, Painkiller8818 said: the result is the same, "i'm having problems to access your emby skill" It does not say it does not understand me My server is not using 443 as the Secure Port, i use the normal emby ports. So is there anything else i need to open except the normal ports? Does the skill require a special port? Thanks The normal ports are fine to use. Have you setup a domain name or are you using a static ip?
Painkiller88 250 Posted August 27, 2024 Posted August 27, 2024 12 hours ago, hatharry said: The normal ports are fine to use. Have you setup a domain name or are you using a static ip? i have a static ip so i don't need dyndns but i have a domain and my server is fully reachable from outside
hatharry 113 Posted August 28, 2024 Posted August 28, 2024 11 hours ago, Painkiller8818 said: i have a static ip so i don't need dyndns but i have a domain and my server is fully reachable from outside In the server dashboard, make sure the remote (wan) access address is correct. Once that is confirmed unlink emby home from Alexa then go through the setup process again
MandyPaul 0 Posted August 28, 2024 Posted August 28, 2024 On 8/25/2024 at 11:23 PM, Painkiller8818 said: the result is the same, "i'm having problems to access your emby skill" It does not say it does not understand me My server is not using 443 as the Secure Port, i use the normal emby ports. So is there anything else i need to open except the normal ports? Does the skill require a special port? Thanks I have the same problem.
LiaraAlis 15 Posted August 28, 2024 Posted August 28, 2024 Same problem here. And it seems that the translation is not really good. It often plays music from Amazon Music instead emby. And if it recognizes that I mean the emby skill, it doesn't work as described.
Painkiller88 250 Posted August 29, 2024 Posted August 29, 2024 On 8/28/2024 at 5:37 AM, hatharry said: In the server dashboard, make sure the remote (wan) access address is correct. Once that is confirmed unlink emby home from Alexa then go through the setup process again i did, it is still not working, but looking at the comments of the others i think it is not a problem of my settings
Painkiller88 250 Posted September 6, 2024 Posted September 6, 2024 Hi, Gibts da jetzt ein Update wie man das lösen kann oder wars das schon wieder mit dem Skill nachdem wir da alles übersetzt haben und jahrelang gewartet haben? Einfach keine Rückmeldung mehr zu geben ist nicht wirklich die feine Art. Etwas support wäre hier nett. Danke
hatharry 113 Posted September 10, 2024 Posted September 10, 2024 On 9/7/2024 at 5:14 AM, Painkiller8818 said: Hi, Gibts da jetzt ein Update wie man das lösen kann oder wars das schon wieder mit dem Skill nachdem wir da alles übersetzt haben und jahrelang gewartet haben? Einfach keine Rückmeldung mehr zu geben ist nicht wirklich die feine Art. Etwas support wäre hier nett. Danke Private message me your IP address and i will check the logs for any errors.
popy 73 Posted October 13, 2024 Posted October 13, 2024 Exact same issue here. Soon or later I am giving up any hopes on emby + Alexa in German...
Painkiller88 250 Posted October 13, 2024 Posted October 13, 2024 9 hours ago, popy said: Exact same issue here. Soon or later I am giving up any hopes on emby + Alexa in German... In the Network Settings you need to change the "secure connection mode" to select "Required for all remote connections", and you need to enter your domain in the external domain field. So you force secure connection for all external connections, this is recommended or lets say a MUST for alexa to work. After that, you need to unlink your alexa emby skill, link it again and run the setup of the skill again, and it should work. Unfortunately it still is unusable because you can't talk to alexa like we would do it in german, instead you need to say, "Alexa ask emby home to play XY," which in german is like you are talking like a jugo "alexa frag emby zuhause zu spielen FILMNAME... Wer redet denn so 1
Luke 42239 Posted October 13, 2024 Posted October 13, 2024 12 hours ago, popy said: Exact same issue here. Soon or later I am giving up any hopes on emby + Alexa in German... Hi there, can you please describe your issue in more detail? Thanks.
popy 73 Posted October 16, 2024 Posted October 16, 2024 On 10/13/2024 at 8:36 PM, Painkiller8818 said: In the Network Settings you need to change the "secure connection mode" to select "Required for all remote connections", and you need to enter your domain in the external domain field. So you force secure connection for all external connections, this is recommended or lets say a MUST for alexa to work. After that, you need to unlink your alexa emby skill, link it again and run the setup of the skill again, and it should work. Unfortunately it still is unusable because you can't talk to alexa like we would do it in german, instead you need to say, "Alexa ask emby home to play XY," which in german is like you are talking like a jugo "alexa frag emby zuhause zu spielen FILMNAME... Wer redet denn so Thanks for the detailed answer. Now I got you, I have to open access router ports for this to work. This is a no go for me, since I have closed my router down an just using home services over wireguard So Alexa+emby will not work for me. Anyways thx for the help.
Luke 42239 Posted October 16, 2024 Posted October 16, 2024 59 minutes ago, popy said: Thanks for the detailed answer. Now I got you, I have to open access router ports for this to work. This is a no go for me, since I have closed my router down an just using home services over wireguard So Alexa+emby will not work for me. Anyways thx for the help. Right it’s not an Emby thing. This is just how Alexa works. 1
