Methodman104 10 Posted October 21, 2021 Posted October 21, 2021 I copied the files from my old pc to the new pc, Emby is running fine, but I notice the cover art from my LiveTV channel that I run no longer displays the cover art for the programs. Is there a way to fix this?
Methodman104 10 Posted October 29, 2021 Author Posted October 29, 2021 (edited) it is running from a live tv channel that I created, the files are an M3U file and XMLTV file. Edited October 29, 2021 by Methodman104
Carlo 4561 Posted October 29, 2021 Posted October 29, 2021 Hi, does your XML file contain this information?
Methodman104 10 Posted November 1, 2021 Author Posted November 1, 2021 On 10/29/2021 at 12:36 AM, cayars said: Hi, does your XML file contain this information? not sure....the XML was basically copied from my old pc and added to my new pc.
Carlo 4561 Posted November 1, 2021 Posted November 1, 2021 I don't think this is typically going to be a file on your PC. More than likely it's what you entered in the URL field when setting up the guide. To see if this info is in that file you would need to download it and take a look at it. If you like you could PM me the URL and I can take a quick look at it as I know the format well. 1
Methodman104 10 Posted November 15, 2021 Author Posted November 15, 2021 Thanks, I will try to find out what the issue is then when I have more time.
Luke 42243 Posted November 16, 2021 Posted November 16, 2021 @Methodman104 Can you show a screenshot of your live tv setup screen?
