frankmomma 2 Posted October 21, 2021 Posted October 21, 2021 Is there a way to change the threshold for when to throttle transcoding when throttling is enabled? By default it looks like this is configured to 120s. I have found the xml where this setting is defined, however after modifying & saving there is no change according to transcoding logs. FYI, this is not an option from Emby management interface. Location of xml file: .../Emby-Server/Config/encoding.xml <ThrottleBufferSize>120</ThrottleBufferSize> Log Example ThrottleBySegmentRequest: RequestPosition: 00:01:03 - TranscodingPosition: 00:02:11 - ThrottleBuffer: 69s (Treshold: 120s) Please let me know if anyone can help determine if this is possible. Thanks
Luke 42197 Posted October 21, 2021 Posted October 21, 2021 Hi, you can edit the config file (make sure to restart server), but it's not exposed in the server UI at this time. It's possible for the future. Thanks.
Happy2Play 9802 Posted October 21, 2021 Posted October 21, 2021 (edited) @frankmomma My understanding is it only applies to "ByStreamBufferSize" not "BySegmentRequest". I made the change per old topic and it honored the configured value. Quote >> ThrottleBySegmentRequest: Initialize - TargetBufferSize: 120s Saved and change xml per linked topic. Quote >> ThrottleByStreamBufferSize: Initialize - TargetBufferSize: 240s - Hysteresis: 8s Edited October 21, 2021 by Happy2Play 1
frankmomma 2 Posted October 21, 2021 Author Posted October 21, 2021 Thank you both for the quick responses. @Luke I tried simply restarting after applying the change but it did not change anything. The xml saved but was not reflected in the logs. @Happy2Play I read the thread you mentioned & tested myself. This resolved the issue! I am now seeing this in the logs. xml changed to <ThrottlingMethod>ByStreamBufferSize</ThrottlingMethod> | Default was <ThrottlingMethod>BySegmentRequest</ThrottlingMethod> ThrottleByStreamBufferSize: PlaybackPosition: 00:00:10 - TranscodingPosition: 00:02:30 - ThrottleBuffer: 140s (Treshold: 300s) Thank you both!
softworkz 5129 Posted October 21, 2021 Posted October 21, 2021 15 minutes ago, Happy2Play said: My understanding is it only applies to "ByStreamBufferSize" not "BySegmentRequest". Yes, that's correct.
