Abobader 3485 Posted October 28, 2021 Author Posted October 28, 2021 I forgot to say, this only temp add on, the one I spoke with the author for the one we remove still did not update yet, when it dose, we will add it back and remove this one.
Abobader 3485 Posted October 28, 2021 Author Posted October 28, 2021 ah, it not good, I just notice when I reply, totally not good, if you fine with I will keep it, otherwise I will remove it.
CBers 7555 Posted October 28, 2021 Posted October 28, 2021 1 minute ago, Abobader said: ah, it not good, I just notice when I reply, totally not good, if you fine with I will keep it, otherwise I will remove it. Perhaps leave it a day or two and see if people complain.
Abobader 3485 Posted October 28, 2021 Author Posted October 28, 2021 50 minutes ago, CBers said: Perhaps leave it a day or two and see if people complain. Yes, that correct.
CassTG 113 Posted November 1, 2021 Posted November 1, 2021 (edited) Some text in dark mode needs contrasting colours i noticed this in certain menu areas Edited November 1, 2021 by CassTG 1 1
Abobader 3485 Posted November 2, 2021 Author Posted November 2, 2021 On 11/1/2021 at 1:57 PM, CassTG said: Some text in dark mode needs contrasting colours i noticed this in certain menu areas I will work on the dark theme this weekend, thanks. 1
Abobader 3485 Posted November 3, 2021 Author Posted November 3, 2021 Good day, We had to upgrade the forum today, for whom notice login problem for a few minutes or so, thanks all. My best 1
Locutus64 125 Posted November 3, 2021 Posted November 3, 2021 Might want to fix it so when someone clicks on a topic under unread content it actually takes them to the latest post in the thread instead of the first post.
GrimReaper 4893 Posted November 3, 2021 Posted November 3, 2021 (edited) 4 minutes ago, Locutus64 said: Might want to fix it so when someone clicks on a topic under unread content it actually takes them to the latest post in the thread instead of the first post. You click on "x minues/hours ago" or "y replies", not Topic header, that'll take you to the latest post in the thread. Edited November 3, 2021 by GrimReaper Typo 2
FrostByte 5452 Posted November 3, 2021 Posted November 3, 2021 You can also go to Account Settings ...Content View Behavior 2
Abobader 3485 Posted November 3, 2021 Author Posted November 3, 2021 If any thing missing before the update please let me know, thanks.
CBers 7555 Posted November 3, 2021 Posted November 3, 2021 1 hour ago, Locutus64 said: Might want to fix it so when someone clicks on a topic under unread content it actually takes them to the latest post in the thread instead of the first post. Click on the GREEN circle, or star if you have posted in the thread. 2
Abobader 3485 Posted November 3, 2021 Author Posted November 3, 2021 On 11/1/2021 at 1:57 PM, CassTG said: Some text in dark mode needs contrasting colours i noticed this in certain menu areas Done. 3
embyL0VER 71 Posted November 7, 2021 Posted November 7, 2021 (edited) Sometimes reply to a topic is not possible. When it's not possible, the bahaviour after clicking "save button" is that "saving..." takes forever. Microsoft Edge Android Edited November 7, 2021 by embyL0VER
GrimReaper 4893 Posted November 7, 2021 Posted November 7, 2021 1 minute ago, embyL0VER said: Sometimes reply to a topic is not possible. When it's not possible, the bahaviour after clicking "save button" is that "saving..." takes forever. Microsoft Edge Android That happens in any mobile browser occasionally (I've had it happen on both Chrome and Opera), mostly on intermittent mobile connection. If you're lucky, backing up and re-entering the thread will have previously typed text remembered/synced/restored, if not, get in the habit of Select all-Copy any content you type - I surely did. 1
embyL0VER 71 Posted November 7, 2021 Posted November 7, 2021 Thx for the answer but can't be the final solution.
GrimReaper 4893 Posted November 7, 2021 Posted November 7, 2021 3 minutes ago, embyL0VER said: Thx for the answer but can't be the final solution. It shouldn't be, but I have lost content so many times that nowdays I do SelectAll>Copy automatically, don't even think about that. Yeah, it's a PITA - but still beats retyping everything all over again.
embyL0VER 71 Posted November 7, 2021 Posted November 7, 2021 Just now, GrimReaper said: Yeah, it's a PITA - but still beats retyping everything all over again. That's for sure. 1
Abobader 3485 Posted November 7, 2021 Author Posted November 7, 2021 Good day, Twitter login disable temp. My best
Abobader 3485 Posted November 7, 2021 Author Posted November 7, 2021 30 minutes ago, embyL0VER said: Sometimes reply to a topic is not possible. When it's not possible, the bahaviour after clicking "save button" is that "saving..." takes forever. Microsoft Edge Android Yes, even in Chrome, as today I face that, I am checking the issue to find the problem then solve the issue, thanks. 1
Abobader 3485 Posted December 8, 2021 Author Posted December 8, 2021 I update the forum today, in case someone faced any issue.
Happy2Play 9811 Posted December 8, 2021 Posted December 8, 2021 (edited) I update the forum today, in case someone faced any issue. I get this when I select Mark site Read Edited December 8, 2021 by Happy2Play
Abobader 3485 Posted December 8, 2021 Author Posted December 8, 2021 2 minutes ago, Happy2Play said: I get this when I select Mark site Read How about now? 2
Happy2Play 9811 Posted December 8, 2021 Posted December 8, 2021 4 minutes ago, Abobader said: How about now? Back to normal. 1
