Abobader 3485 Posted October 20, 2021 Posted October 20, 2021 Good day, We upgrade the forum, as always great work from our Admin's team Luke, Ebr, and John (great works buddy!). Yes, another thread as you know by now If you find any thing, please report it back on this thread, thanks to you all. We testing something at the moment, but will report as it done, also I will add dark theme later. You will notice that reputations points do not show on usersinfo, yes, it was removed in this new build, in case you wonder about that, but it there in the users profile. My best 3
Abobader 3485 Posted October 20, 2021 Author Posted October 20, 2021 Forgot to mention that this build of forum support push notification, as setup by members: Example: 1
PenkethBoy 2068 Posted October 20, 2021 Posted October 20, 2021 not showing any push options for me not that i would use them anyway 1
neik 874 Posted October 20, 2021 Posted October 20, 2021 13 minutes ago, PenkethBoy said: not showing any push options for me not that i would use them anyway You probably would need to activate them first in the bottom of the notification settings: But same here: I don't and won't using push notifications, more a nice to have for regular users imo but for staff members this can maybe help provide better/faster support. 1
PenkethBoy 2068 Posted October 20, 2021 Posted October 20, 2021 (edited) interesting i get a red "permission denied" in this broswer (chrome) rather than enable [edit} updated chrome to ver 95 and no change Edited October 20, 2021 by PenkethBoy
CBers 7554 Posted October 20, 2021 Posted October 20, 2021 (edited) 1 hour ago, PenkethBoy said: interesting i get a red "permission denied" in this broswer (chrome) rather than enable [edit} updated chrome to ver 95 and no change So do I. I think it just means we've disabled PUSH notifications within Chrome. You can re-enable them in Chrome if you click on the padlock to the left of the URL in the address bar. Then change the setting to what you want. I think that should do it. Edited October 20, 2021 by CBers 1
Abobader 3485 Posted October 20, 2021 Author Posted October 20, 2021 @CBers As requested, post counts as before. 1
CBers 7554 Posted October 20, 2021 Posted October 20, 2021 11 minutes ago, Abobader said: @CBers As requested, post counts as before. Thanks.
CBers 7554 Posted October 20, 2021 Posted October 20, 2021 50 minutes ago, Abobader said: @CBers As requested, post counts as before. Sorry Abo, but can you add Rep back as well please.
Abobader 3485 Posted October 20, 2021 Author Posted October 20, 2021 25 minutes ago, CBers said: Sorry Abo, but can you add Rep back as well please. Done. 1
CBers 7554 Posted October 20, 2021 Posted October 20, 2021 11 minutes ago, Abobader said: Done. You're a star, thanks. 1
Abobader 3485 Posted October 20, 2021 Author Posted October 20, 2021 heh, thanks buddy, but @softworkz not happy I am ready for his list 1
GrimReaper 4894 Posted October 20, 2021 Posted October 20, 2021 (edited) Maybe it's just my eye being used to it, but FWIW I preferred the previous iteration with Rep/Solved and Total posts beneath. Edit: In addition, why is there a blank line between Role and Rep? Can we make it more cohesive? Edited October 20, 2021 by GrimReaper Append
Abobader 3485 Posted October 20, 2021 Author Posted October 20, 2021 I think this look better on the eyes, the space as it from the core forum itself and will conflict with other profile if we remove it and then add that profile, but in few days we will organize. At the moment, I have some issue with plugins we used that do not work well with this forum update. 1
GrimReaper 4894 Posted October 20, 2021 Posted October 20, 2021 (edited) 19 minutes ago, Abobader said: I think this look better on the eyes I reckon we can agree to disagree there. Both Rep and Solved are external "data", i.e. not under member control, and fall under same category, whereas Total posts is internal, i.e. strictly member-controlled. Having Solved next to Total posts kinda doesn't make sense, at least to me. And that spacing was the first thing I noticed, feels like an eye poke to me personally - but then again, we each have our own prefernces and inclinations. Anyway, I understand it's still work-in-progress, was just expressing what's bothering me. Cheers Edited October 20, 2021 by GrimReaper Append
Abobader 3485 Posted October 20, 2021 Author Posted October 20, 2021 heh, yes I agree, you tilling the wrong guy here Well, that IPS new organized settings, yes, it not good. I was saying "good on the eyes" for the reputation (green total points). I can place under posts/solutions if you all like that better.
Abobader 3485 Posted October 20, 2021 Author Posted October 20, 2021 Keeps the feedback guys, you all are great, thanks in advance for all this. I will as always make a list to the issue to fix or modify that you all reported. Well done all.
Spaceboy 2573 Posted October 20, 2021 Posted October 20, 2021 where has the jump to top button gone from the bottom right?
Happy2Play 9811 Posted October 21, 2021 Posted October 21, 2021 2 hours ago, Spaceboy said: where has the jump to top button gone from the bottom right? Was just coming here to request it again.@Abobader
Abobader 3485 Posted October 21, 2021 Author Posted October 21, 2021 4 hours ago, Spaceboy said: where has the jump to top button gone from the bottom right? 1 hour ago, Happy2Play said: Was just coming here to request it again.@Abobader I add another one that work with forum new build. 1
CBers 7554 Posted October 21, 2021 Posted October 21, 2021 I wish it would actually jump to the top and not scroll all the way.
Happy2Play 9811 Posted October 21, 2021 Posted October 21, 2021 13 minutes ago, CBers said: I wish it would actually jump to the top and not scroll all the way. Same happens when entering post also. It scrolls to latest post instead of jumping directly to it. 1
