mshaik 2 Posted October 20, 2021 Posted October 20, 2021 (edited) Hi I have a raspberry pi 4 with Open Media vault installed and trying to run a emby docker container via portainer. The Container shows running and the logs good, but when I try to reach the <ipaddress>:8096, I always see Connection refused. Tried doing curl for localhost:8096 got the following : curl: (7) Failed to connect to 172.17.0.3 port 8096: Connection refused This is my compose: --- version: "2.3" services: emby: image: ghcr.io/linuxserver/emby:4.6.4.0-ls90 container_name: emby network_mode: host environment: - PUID=1001 - PGID=100 - TZ=US/Eastern - UNMASK=022 ports: - 8096:8096 - 8920:8920 volumes: - /srv/dev-disk-by-uuid-32d9b906-d378-4166-8fc0-387e0a7d5fd2/Data/Emby/Config:/config - /srv/dev-disk-by-uuid-32d9b906-d378-4166-8fc0-387e0a7d5fd2/Data/Emby/Movies:/data/movies - /srv/dev-disk-by-uuid-32d9b906-d378-4166-8fc0-387e0a7d5fd2/Data/Emby/Photos:/data/photos - /srv/dev-disk-by-uuid-2ac3c9e9-ee7f-4403-ac81-d1b38c841df8/FlashDrive2/Data/Animated:/data/animated - /srv/dev-disk-by-uuid-cc6fd87a-1e94-4440-bf81-a9aae216459a/SecondarySSD/Emby/Atmos:/data/atmos restart: unless-stopped Tried checking ports sudo lsof -i -P -n | grep LISTEN systemd 1 root 25u IPv4 11278 0t0 TCP *:111 (LISTEN) systemd 1 root 27u IPv6 11281 0t0 TCP *:111 (LISTEN) systemd-r 456 systemd-resolve 12u IPv4 18124 0t0 TCP *:5355 (LISTEN) systemd-r 456 systemd-resolve 14u IPv6 18127 0t0 TCP *:5355 (LISTEN) systemd-r 456 systemd-resolve 17u IPv4 18130 0t0 TCP 127.0.0.53:53 (LISTEN) rpcbind 822 _rpc 4u IPv4 11278 0t0 TCP *:111 (LISTEN) rpcbind 822 _rpc 6u IPv6 11281 0t0 TCP *:111 (LISTEN) sshd 826 root 3u IPv4 19993 0t0 TCP *:22 (LISTEN) sshd 826 root 4u IPv6 19995 0t0 TCP *:22 (LISTEN) rpc.mount 828 root 9u IPv4 20002 0t0 TCP *:57583 (LISTEN) rpc.mount 828 root 11u IPv6 20006 0t0 TCP *:39043 (LISTEN) rpc.mount 828 root 13u IPv4 20010 0t0 TCP *:59693 (LISTEN) rpc.mount 828 root 15u IPv6 20014 0t0 TCP *:33951 (LISTEN) rpc.mount 828 root 17u IPv4 20018 0t0 TCP *:45533 (LISTEN) rpc.mount 828 root 19u IPv6 20022 0t0 TCP *:44535 (LISTEN) nginx 845 root 8u IPv6 20766 0t0 TCP *:80 (LISTEN) nginx 846 www-data 8u IPv6 20766 0t0 TCP *:80 (LISTEN) nginx 847 www-data 8u IPv6 20766 0t0 TCP *:80 (LISTEN) nginx 849 www-data 8u IPv6 20766 0t0 TCP *:80 (LISTEN) nginx 851 www-data 8u IPv6 20766 0t0 TCP *:80 (LISTEN) docker-pr 1214 root 4u IPv4 24836 0t0 TCP *:9000 (LISTEN) docker-pr 1220 root 5u IPv6 24841 0t0 TCP *:9000 (LISTEN) docker-pr 1258 root 4u IPv4 25715 0t0 TCP *:8000 (LISTEN) docker-pr 1268 root 4u IPv6 24869 0t0 TCP *:8000 (LISTEN) docker-pr 19312 root 4u IPv4 77333 0t0 TCP *:8920 (LISTEN) docker-pr 19319 root 4u IPv6 77338 0t0 TCP *:8920 (LISTEN) docker-pr 19333 root 4u IPv4 79132 0t0 TCP *:8096 (LISTEN) docker-pr 19339 root 4u IPv6 77343 0t0 TCP *:8096 (LISTEN) Here's the network details of the Docker Container: sudo iptables -t nat -L -n Chain PREROUTING (policy ACCEPT) target prot opt source destination DOCKER all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL Chain INPUT (policy ACCEPT) target prot opt source destination Chain POSTROUTING (policy ACCEPT) target prot opt source destination MASQUERADE all -- 172.17.0.0/16 0.0.0.0/0 MASQUERADE tcp -- 172.17.0.2 172.17.0.2 tcp dpt:9000 MASQUERADE tcp -- 172.17.0.2 172.17.0.2 tcp dpt:8000 MASQUERADE tcp -- 172.17.0.3 172.17.0.3 tcp dpt:8920 MASQUERADE tcp -- 172.17.0.3 172.17.0.3 tcp dpt:8096 Chain OUTPUT (policy ACCEPT) target prot opt source destination DOCKER all -- 0.0.0.0/0 !127.0.0.0/8 ADDRTYPE match dst-type LOCAL Chain DOCKER (2 references) target prot opt source destination RETURN all -- 0.0.0.0/0 0.0.0.0/0 DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:9000 to:172.17.0.2:9000 DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:8000 to:172.17.0.2:8000 DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:8920 to:172.17.0.3:8920 DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:8096 to:172.17.0.3:8096 Container statrup logs: [s6-init] making user provided files available at /var/run/s6/etc...exited 0., [s6-init] ensuring user provided files have correct perms...exited 0., [fix-attrs.d] applying ownership & permissions fixes..., [fix-attrs.d] done., [cont-init.d] executing container initialization scripts..., [cont-init.d] 01-envfile: executing... , [cont-init.d] 01-envfile: exited 0., [cont-init.d] 10-adduser: executing... , , -------------------------------------, _ (), | | ___ _ __, | | / __| | | / \, | | \__ \ | | | () |, |_| |___/ |_| \__/, , , Brought to you by linuxserver.io, -------------------------------------, , To support LSIO projects visit:, https://www.linuxserver.io/donate/, -------------------------------------, GID/UID, -------------------------------------, , User uid: 1001, User gid: 100, -------------------------------------, , , @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@, , Your DockerHost is most likely running an outdated version of libseccomp, , To fix this, please visit https://docs.linuxserver.io/faq#libseccomp, , Some apps might not behave correctly without this, , @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@, , [cont-init.d] 10-adduser: exited 0., [cont-init.d] 30-config: executing... , [cont-init.d] 30-config: exited 0., [cont-init.d] 40-gid-video: executing... , [cont-init.d] 40-gid-video: exited 0., [cont-init.d] 90-custom-folders: executing... , [cont-init.d] 90-custom-folders: exited 0., [cont-init.d] 99-custom-scripts: executing... , [custom-init] no custom files found exiting..., [cont-init.d] 99-custom-scripts: exited 0., [cont-init.d] done., [services.d] starting services, [services.d] done. I have portainer running in docker on port 9000 and it works perfectly fine. Tried installing several times using network_mode host and bridge, also using various emby tags i.e latest ,4.6.4.0 I tried installing emby normally without docker and it works perfectly, but I want to deploy via docker container and have proxy and ssl certificates over the container. DockerInspect.txt Edited October 20, 2021 by mshaik added new logs
mshaik 2 Posted October 20, 2021 Author Posted October 20, 2021 I also checked the noexec issue for the mounts and they don't have noexec, Here's the fstab details. <mntent> <uuid>270f1e9f-e6ac-467b-8295-784f12f5b871</uuid> <fsname>/dev/disk/by-uuid/32d9b906-d378-4166-8fc0-387e0a7d5fd2</fsname> <dir>/srv/dev-disk-by-uuid-32d9b906-d378-4166-8fc0-387e0a7d5fd2</dir> <type>ext4</type> <opts>defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl</opts> <freq>0</freq> <passno>2</passno> <hidden>0</hidden> </mntent> <mntent> <uuid>9f093f04-3562-4a43-a531-286cf5cf9cb0</uuid> <fsname>/dev/disk/by-uuid/2ac3c9e9-ee7f-4403-ac81-d1b38c841df8</fsname> <dir>/srv/dev-disk-by-uuid-2ac3c9e9-ee7f-4403-ac81-d1b38c841df8</dir> <type>ext4</type> <opts>defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl</opts> <freq>0</freq> <passno>2</passno> <hidden>0</hidden> </mntent> <mntent> <uuid>49ee608c-0c89-47d8-83bd-034fc7609f66</uuid> <fsname>/dev/disk/by-uuid/cc6fd87a-1e94-4440-bf81-a9aae216459a</fsname> <dir>/srv/dev-disk-by-uuid-cc6fd87a-1e94-4440-bf81-a9aae216459a</dir> <type>ext4</type> <opts>defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl</opts> <freq>0</freq> <passno>2</passno> <hidden>0</hidden> </mntent> <mntent> <uuid>61cb6955-2bdb-469c-bcf8-6d177d5877e5</uuid> <fsname>/dev/disk/by-uuid/0297fbbf-88fe-42bb-9fe5-f8edbfad68a2</fsname> <dir>/srv/dev-disk-by-uuid-0297fbbf-88fe-42bb-9fe5-f8edbfad68a2</dir> <type>ext4</type> <opts>defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl</opts> <freq>0</freq> <passno>2</passno> <hidden>0</hidden> </mntent> </fstab>
Q-Droid 1011 Posted October 20, 2021 Posted October 20, 2021 Did the emby server start and create a log?
mshaik 2 Posted October 20, 2021 Author Posted October 20, 2021 No @Q-Droid the install itself is exiting, I added the logs too.
Q-Droid 1011 Posted October 20, 2021 Posted October 20, 2021 Have you made sure that the runtime user (PUID) can write to the /config volume? I don't know why you're using the Linuxserver docker image though it could be a Pi thing. If not then you should be using the official Emby image.
Solution mshaik 2 Posted October 20, 2021 Author Solution Posted October 20, 2021 I am using Debian Emby only, I found the issue anyhow, the issue with Raspberry Pi has old library for the following. Updated it and used backport and everything works cool now. Solution Raspbian has a version of libseccomp2 that is too old to support running a docker container based on Ubuntu 20.04, which both hotio and LinuxServer use as their base for v3. You either need to use --privileged, update libseccomp2 from Ubuntu or get a better OS (We recommend Ubuntu 20.04 arm64) Possible Solution: Managed to fix the issue by installing the backport from debian repo. Generally not recommended to use backport in blanket upgrade mode. Installation of a single package may be ok but may also cause issues. So got to understand what you are doing. Steps to fix: First ensure you are running Raspbian buster e.g using lsb_release -a Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster Just run the following Command: wget http://ftp.debian.org/debian/pool/main/libs/libseccomp/libseccomp2_2.5.1-1~bpo10+1_armhf.deb sudo dpkg -i libseccomp2_2.5.1-1~bpo10+1_armhf.deb Once this is installed, the docker will work as expected.
Luke 42246 Posted October 20, 2021 Posted October 20, 2021 Glad you figured it out. Thanks for the feedback.
