gungatim 10 Posted October 19, 2021 Posted October 19, 2021 My scheduled shows stopped recording and I am going through the log and keep seeing all these errors. I can still watch live tv, and manually record, but nothing scheduled will record for some reason. can I get some direction on how to fix these errors so it will work again? 2 main errors: *** Error Report *** Version: 4.6.4.0 Command line: C:\Users\timsc\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.19041 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/timsc/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\timsc\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\timsc\AppData\Roaming\Emby-Server\system MediaBrowser.Common.Extensions.ResourceNotFoundException: MediaBrowser.Common.Extensions.ResourceNotFoundException: 1181997 does not have an image of type LogoLightColor at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Api TargetSite: Void MoveNext() *** Error Report *** Version: 4.6.4.0 Command line: C:\Users\timsc\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.19041 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/timsc/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\timsc\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\timsc\AppData\Roaming\Emby-Server\system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: Received an invalid status line: 'HTTP1.1 400 Bad Request'. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMapInternal(Mapping mapping, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() here is where it was supposed to record my 9pm shows and did not: 2021-10-18 08:57:03.166 Info Server: http/1.1 GET http://localhost:8096/emby/LiveTv/Channels?userId=28b50f0b7d7f4983966555fe158b7f1f&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=DefaultChannelOrder&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=bf2e910f-7834-4560-b41d-a705247be6e2&X-Emby-Client-Version=4.6.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.81 Safari/537.36 Edg/94.0.992.50 2021-10-18 08:57:03.171 Info App: [NextPvr] Start GetTimer Async, retrieve the 'Pending' recordings 2021-10-18 08:57:03.171 Info App: [NextPvr] Start InitiateSession 2021-10-18 08:57:03.171 Info HttpClient: GET http://localhost:8866/public/Util/NPVR/Client/Instantiate 2021-10-18 08:57:03.181 Info App: [NextPvr] Sid: 326847b3b36e4cbdad05511805ef7aea 2021-10-18 08:57:03.181 Info App: [NextPvr] Start Login procedure for Sid: 326847b3b36e4cbdad05511805ef7aea & Salt: 9b34814d-b777-43fd-8cb8-c407dc85ef72 2021-10-18 08:57:03.181 Info App: [NextPvr] Pin: 0000 2021-10-18 08:57:03.181 Info HttpClient: GET http://localhost:8866/public/Util/NPVR/Client/Initialize/eb087f7a706eba594a90f92d759324f7?sid=326847b3b36e4cbdad05511805ef7aea 2021-10-18 08:57:03.189 Info App: [NextPvr] Session initiated. 2021-10-18 08:57:03.189 Info HttpClient: POST http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=326847b3b36e4cbdad05511805ef7aea 2021-10-18 08:57:03.199 Info App: [NextPvr] Start GetSeriesTimer Async, retrieve the recurring recordings 2021-10-18 08:57:03.199 Info HttpClient: POST http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=326847b3b36e4cbdad05511805ef7aea 2021-10-18 08:57:03.206 Info Server: http/1.1 Response 200 to ::1. Time: 40ms. http://localhost:8096/emby/LiveTv/Channels?userId=28b50f0b7d7f4983966555fe158b7f1f&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=DefaultChannelOrder&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=bf2e910f-7834-4560-b41d-a705247be6e2&X-Emby-Client-Version=4.6.4.0 2021-10-18 09:00:26.497 Info App: [NextPvr] Start GetRecordings Async, retrieve all 'Pending', 'Inprogress' and 'Completed' recordings 2021-10-18 09:00:26.497 Info HttpClient: POST http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=326847b3b36e4cbdad05511805ef7aea 2021-10-18 09:02:16.167 Info Server: http/1.1 GET http://localhost:8096/emby/LiveTv/Channels?userId=28b50f0b7d7f4983966555fe158b7f1f&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=DefaultChannelOrder&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=bf2e910f-7834-4560-b41d-a705247be6e2&X-Emby-Client-Version=4.6.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.81 Safari/537.36 Edg/94.0.992.50 2021-10-18 09:02:16.172 Info App: [NextPvr] Start GetTimer Async, retrieve the 'Pending' recordings 2021-10-18 09:02:16.172 Info App: [NextPvr] Start InitiateSession 2021-10-18 09:02:16.172 Info HttpClient: GET http://localhost:8866/public/Util/NPVR/Client/Instantiate 2021-10-18 09:02:16.181 Info App: [NextPvr] Sid: 8b0145f4146042f89a413f471f92e256 2021-10-18 09:02:16.181 Info App: [NextPvr] Start Login procedure for Sid: 8b0145f4146042f89a413f471f92e256 & Salt: 2f620aaf-5424-425b-bb26-541f8c4fb077 2021-10-18 09:02:16.181 Info App: [NextPvr] Pin: 0000 2021-10-18 09:02:16.181 Info HttpClient: GET http://localhost:8866/public/Util/NPVR/Client/Initialize/ec7ad7826eea6c7dce05cb1a8d943a4a?sid=8b0145f4146042f89a413f471f92e256 2021-10-18 09:02:16.189 Info App: [NextPvr] Session initiated. 2021-10-18 09:02:16.189 Info HttpClient: POST http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=8b0145f4146042f89a413f471f92e256 2021-10-18 09:02:16.198 Info App: [NextPvr] Start GetSeriesTimer Async, retrieve the recurring recordings 2021-10-18 09:02:16.198 Info HttpClient: POST http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=8b0145f4146042f89a413f471f92e256 2021-10-18 09:02:16.205 Info Server: http/1.1 Response 200 to ::1. Time: 38ms. http://localhost:8096/emby/LiveTv/Channels?userId=28b50f0b7d7f4983966555fe158b7f1f&IsAiring=true&ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&Fields=ProgramPrimaryImageAspectRatio&EnableUserData=false&Limit=12&SortBy=DefaultChannelOrder&SortOrder=Ascending&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=bf2e910f-7834-4560-b41d-a705247be6e2&X-Emby-Client-Version=4.6.4.0 2021-10-18 09:02:42.296 Error PortMapper: Error creating port map *** Error Report *** Version: 4.6.4.0 Command line: C:\Users\timsc\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.19041 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/timsc/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\timsc\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\timsc\AppData\Roaming\Emby-Server\system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: Received an invalid status line: 'HTTP1.1 400 Bad Request'. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMapInternal(Mapping mapping, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext()
Carlo 4561 Posted October 19, 2021 Posted October 19, 2021 Hi, Turn off port mapping in your network menu as it's just adding errors to your log file making them harder to read. Looking at this log fragment it appears to be using NextPVR for the recording so I would check to make sure basic communication is working between Emby and NextPVR. Can you view live tv? We need the full log preferably after you make the port mapper change to look at.
gungatim 10 Posted October 19, 2021 Author Posted October 19, 2021 I had port mapping on because I've been trying for 2 years to get remote access to work but it's impossible to open any ports apparently using LTE wifi...I will turn it off. is NextPVR what the Haughpauge tuner uses? (WinTV8) I noticed I had it set to record because Emby wasn't working and it was froze up last night (said it was still recording 2 shows at 9pm that never recorded and still showed recording this morning so I rebooted and deleted all the WinTV schedule which may have been the issue)
gungatim 10 Posted October 19, 2021 Author Posted October 19, 2021 Thank You by the way. Port mapping is now unchecked, and I am restarting Emby. I have a few show scheduled at 1pm so I will see if it works and report back.
Carlo 4561 Posted October 19, 2021 Posted October 19, 2021 NextPVR is showing as I'd assume you have that plugin installed. This will only work if you also have a NextPVR server installed and configured to work with the plugin. For a Hauppauge tuner with WinTV running on the server you do not need this.
gungatim 10 Posted October 19, 2021 Author Posted October 19, 2021 uninstalled nextPVR. do you know what the errors "ResourceNotFoundException: 1181997 does not have an image of type LogoLightColor" means? there are quite a few of those where the number preceding the "does not have an image" is different but the rest of the error is the same. I assume I have some bad artwork somewhere but don't know where to look.
Luke 42197 Posted October 19, 2021 Posted October 19, 2021 4 hours ago, gungatim said: uninstalled nextPVR. do you know what the errors "ResourceNotFoundException: 1181997 does not have an image of type LogoLightColor" means? there are quite a few of those where the number preceding the "does not have an image" is different but the rest of the error is the same. I assume I have some bad artwork somewhere but don't know where to look. HI there @gungatim, let's look at an example. please attach the emby server log from that. thanks.
gungatim 10 Posted October 19, 2021 Author Posted October 19, 2021 Well it's working again, 10 episodes of Counting Cars got recorded. Thanks for the help! 1
