Mibok 158 Posted October 19, 2021 Posted October 19, 2021 (edited) Currently Emby shows a countdown 35 seconds before a series episode ends, with a button for "Play now" next episode. What i'm proposing similar to that but somehow reversed, i mean using the setting on "Max resume percentage" as the point where a countdown (if possible shorter than 35 sec.) starts automatically the next episode and the button instead of "Play now" will say something like "Don't skip". This would work as an Ending Skip tool, most series (Specially anime) tends to have the ending at the same percentage of completion, this could be an per library setting and the "Don't skip" option could be useful if the series have an after credit scene. Edited October 19, 2021 by Mibok
ebr 16339 Posted October 19, 2021 Posted October 19, 2021 Hi. There are existing requests for turning the logic around from needing to take action to keep the item from playing to needing to take action to make it play. As for keying this off of the max resume percent value, I really think that is unrelated and not a very good idea. 1
