GloverEggs 9 Posted October 18, 2021 Posted October 18, 2021 The guide is incorrect for 65.3 in El Paso, TX/Las Cruces, NM area. And yes, if I go to the channel, it's different than what eh guide says. This site https://www.ontvtonight.com/guide/listings/ElPasoNight.html shows the correct data for 65.3 which is labeled as "Quest." Thanks.
GloverEggs 9 Posted October 18, 2021 Author Posted October 18, 2021 Forgot to note that my Hauppauge guide also shows the channel correctly.
Carlo 4561 Posted October 18, 2021 Posted October 18, 2021 I see the same issue. It's showing as LATV vs Quest but the other 2 virtual channels appear correct. I'm reporting this to our guide provider.
Carlo 4561 Posted October 20, 2021 Posted October 20, 2021 Would you mind trying something for me? Add a new guide for Odessa with zip 79760 selecting the OTA lineup. When adding it deselect all the tuners so it doesn't try and automat to anything you already have. Now go into the Channel lineup and manually map only your Quest channel on 65.3 to the Odessa/79760 guide using channel 9.4. 9.4 Odessa OTA should be KWESDT4/QUESTSD. Does that guide match what's actually on for you? I would think so since it's the same general area and I believe the closest OTA station to you. Let me know how this works for you.
