MBSki 1115 Posted October 18, 2021 Posted October 18, 2021 The image size used seems to be determined by the first item added. So if I add a TV episode first, the images are all landscape. If a movie is first all the images are portrait. In the Android TV app the images are all sized correctly based on the content type. @Luke Can you please fix? The web app has the wrong size images too. Android mobile pic:
roaku 842 Posted October 18, 2021 Posted October 18, 2021 There's nothing to fix. Emby is doing its best with the mix of image aspect ratios it's being given. https://emby.media/community/index.php?/topic/102057-series-library-thumbnail-aspect-ratio-changing-on-its-own/&do=findComment&comment=1072436
MBSki 1115 Posted October 18, 2021 Author Posted October 18, 2021 3 minutes ago, roaku said: There's nothing to fix. Emby is doing its best with the mix of image aspect ratios it's being given. https://emby.media/community/index.php?/topic/102057-series-library-thumbnail-aspect-ratio-changing-on-its-own/&do=findComment&comment=1072436 Actually, that's not true. @ebr was able to mix aspect ratios in the Android TV app. See below.
roaku 842 Posted October 18, 2021 Posted October 18, 2021 The only difference I see there is that there's no background framing the image. The mixed aspect ratios are the same in both cases.
MBSki 1115 Posted October 18, 2021 Author Posted October 18, 2021 7 minutes ago, roaku said: The only difference I see there is that there's no background framing the image. The mixed aspect ratios are the same in both cases. The images are different sizes. Either way, it looks better. So, maybe I just need to change the title to, "make the images in collections with TV episodes and movies look better". Does that work?
Luke 42243 Posted October 18, 2021 Posted October 18, 2021 It's not based on the first item. It's a calculation based on all of the items on the first page.
Luke 42243 Posted October 18, 2021 Posted October 18, 2021 1 hour ago, roaku said: The only difference I see there is that there's no background framing the image. The mixed aspect ratios are the same in both cases. Yes, the mobile screenshot looks good to me.
MBSki 1115 Posted October 18, 2021 Author Posted October 18, 2021 6 hours ago, Luke said: Yes, the mobile screenshot looks good to me. No it doesn't. The Android TV version looks much better. It's using a wider size for the episodes than it is for the movies. You can see the difference in my screenshot above right? 1
roaku 842 Posted October 18, 2021 Posted October 18, 2021 2 hours ago, mbarylski said: No it doesn't. The Android TV version looks much better. It's using a wider size for the episodes than it is for the movies. You can see the difference in my screenshot above right? Again, the app is doing the best it can with the mix of aspect ratios it's being given. In the Android case, the spacing between images is being reduced to compensate for the wider images. In the web app, the image width is constant to preserve the look of a grid. Neither are wrong or broken. You just prefer one method of dealing with the mixed images over the other. I happen to dislike the inconsistent spacing more than the constant width with background.
MBSki 1115 Posted October 18, 2021 Author Posted October 18, 2021 15 minutes ago, roaku said: Again, the app is doing the best it can with the mix of aspect ratios it's being given. Again, no it isn't. The Android TV app looks better. The web and Android apps could be made to look better too, and I don't know why you keep refuting that simple point.
roaku 842 Posted October 18, 2021 Posted October 18, 2021 12 minutes ago, mbarylski said: Again, no it isn't. The Android TV app looks better. The web and Android apps could be made to look better too, and I don't know why you keep refuting that simple point. You're substituting your personal preference for 'best', and my point is still that they're all compensating for the fundamental problem of inconsistent images. Different users are going to like different workarounds more than others, but they're all workarounds.
MBSki 1115 Posted October 18, 2021 Author Posted October 18, 2021 No I'm not. For some reason you're refusing to even consider that it could be changed to look better. Just consider for a second that the Android TV app does it better. At a bare minimum get rid of the extra black bars around the episodes. Can you at least concede that getting rid of the black bars would make it look better?
roaku 842 Posted October 18, 2021 Posted October 18, 2021 1 minute ago, mbarylski said: No I'm not. For some reason you're refusing to even consider that it could be changed to look better. Just consider for a second that the Android TV app does it better. At a bare minimum get rid of the extra black bars around the episodes. Can you at least concede that getting rid of the black bars would make it look better? I do not agree with your opinion.
MBSki 1115 Posted October 18, 2021 Author Posted October 18, 2021 Just now, roaku said: I do not agree with your opinion. Unbelievable. @Luke Could you please at least consider just getting rid of the black bars?
