Joechung 5 Posted October 16, 2021 Posted October 16, 2021 Dear EMBY technician: How can I name it so that EMBY does not recognize it? Since I want to keep this file, I don't want to move it. Now EMBY automatically recognizes it and makes a mess of my library. I think EMBY can't recognize it.
Luke 42240 Posted October 16, 2021 Posted October 16, 2021 Hi, there is currently no way to ignore individual files, but you can ignore entire folders using the .ignore technique. @cayars can point you to the help topic on that. Thanks.
Solution Carlo 4561 Posted October 17, 2021 Solution Posted October 17, 2021 https://support.emby.media/support/solutions/articles/44001159118-excluding-files-folders This is the shortest KB article ever! Ready, here it is: To exclude a folder from the library scan, simply place a file inside the folder named .ignore This will cause Emby to ignore all subfolders as well.
Joechung 5 Posted October 17, 2021 Author Posted October 17, 2021 1 minute ago, cayars said: https://support.emby.media/support/solutions/articles/44001159118- exclude-files-folders 这是有史以来最短的 KB 文章! 准备好了,来了: 要从库扫描中排除文件夹,只需在名为 .ignore 的文件夹中放置一个文件 这将导致 Emby 也忽略所有子文件夹。 HI ,Thank you for the
Dryparn 0 Posted November 2, 2021 Posted November 2, 2021 If i want to exclude the files in a folder but not exclude its subfolders then?
Luke 42240 Posted November 2, 2021 Posted November 2, 2021 2 minutes ago, Dryparn said: If i want to exclude the files in a folder but not exclude its subfolders then? HI, there is currently no way to do that. Thanks.
