SamES 1084 Posted June 21, 2022 Posted June 21, 2022 Can you please also attach the server log? @Luke, I expected these to use fMP4 segments, but they still appear to be ts. Did I miss something in my changes?
Luke 42239 Posted June 21, 2022 Posted June 21, 2022 1 hour ago, SamES said: Can you please also attach the server log? @Luke, I expected these to use fMP4 segments, but they still appear to be ts. Did I miss something in my changes? It requires the 4.7 server.
SamES 1084 Posted June 22, 2022 Posted June 22, 2022 1 hour ago, Luke said: It requires the 4.7 server. Of course! @teicangare you able to update to the latest stable server release and repeat these tests and confirm they are still good. Let me know if you’re not able to update to the latest stable.
teicang 34 Posted June 22, 2022 Posted June 22, 2022 (edited) Hi Sam, for server log I can take it friday , I'm now out of my house and I cannot running again the movies ,(I don't remeber what I saw last time so if I download now the server log could not be aligned with the movies with the problem). Actually I have the 4.6.7.0 ver but the system say this is the last version. SO if I need to update I have to update it manually, I also checked from NAS terramaster point of view but there isn't yet any update. Do you validate the 4.7 ver also towards terramster NAS? \Gianni Edited June 22, 2022 by teicang
FrostByte 5453 Posted June 22, 2022 Posted June 22, 2022 I know with Synology it can take some time for an update to get into the store while they do their own testing. Sometimes it takes them 2 - 3 weeks which is why I always manually update. 1
teicang 34 Posted June 22, 2022 Posted June 22, 2022 16 minutes ago, FrostByte said: I know with Synology it can take some time for an update to get into the store while they do their own testing. Sometimes it takes them 2 - 3 weeks which is why I always manually update. For manual update witch version of emmby server : 64-Bit or ARMv8 , could l Ioad for a NAS model F2-220 ??? Because from the NAS spec I read CPU ARM V8 64-bit , so the two version together so both are ok?
FrostByte 5453 Posted June 22, 2022 Posted June 22, 2022 49 minutes ago, teicang said: For manual update witch version of emmby server : 64-Bit or ARMv8 , could l Ioad for a NAS model F2-220 ??? Because from the NAS spec I read CPU ARM V8 64-bit , so the two version together so both are ok? They're both 64-bit cpus, but the download labeled 64-bit is for Intel cpus Confusing The F2-220 websites I found all say it has an Intel processor, which would be the 64-bit download. Are there more then one version of the F2-220? However, I don't believe it will let you install the wrong one.
teicang 34 Posted June 22, 2022 Posted June 22, 2022 5 minutes ago, FrostByte said: They're both 64-bit cpus, but the download labeled 64-bit is for Intel cpus Confusing The F2-220 websites I found all say it has an Intel processor, which would be the 64-bit download. Are there more then one version of the F2-220? However, I don't believe it will let you install the wrong one. No exist one oly model F2-220 , I have also another one more "strong" but the model F2-422
FrostByte 5453 Posted June 22, 2022 Posted June 22, 2022 (edited) This is the processor I found to be in the F2-220 online Intel® Celeron® Processor J1800 If that's what you have then try the "64-bit" download Edited June 22, 2022 by FrostByte
teicang 34 Posted June 22, 2022 Posted June 22, 2022 11 hours ago, SamES said: Of course! @teicangare you able to update to the latest stable server release and repeat these tests and confirm they are still good. Let me know if you’re not able to update to the latest stable. @SamES do you need the server log however, if I try to update the server to 4.7 I'm not be able anymore to get the server log in 4.6 let me know @Luke @frostbiteTO update manually the server, have I stop the server and without remove it start the update or have I need also to remove the old one? 1
FrostByte 5453 Posted June 22, 2022 Posted June 22, 2022 Shutdown Emby server, then install. It should upgrade your previous version 1 1
SamES 1084 Posted June 22, 2022 Posted June 22, 2022 36 minutes ago, teicang said: do you need the server log however, if I try to update the server to 4.7 I'm not be able anymore to get the server log in 4.6 let me know No need for old server log. We can check again with 4.7. Thanks
teicang 34 Posted June 22, 2022 Posted June 22, 2022 2 hours ago, FrostByte said: Shutdown Emby server, then install. It should upgrade your previous version Server updated from remote , unfortunatelly to test it I have to stay in front on my wonderfull TV , so on friday I'll be able to make the test thxxx to all , great team :-)))) 2
teicang 34 Posted June 23, 2022 Posted June 23, 2022 (edited) Hi Sam, i start to makemsome test but i'm getting some problem. The 4k movies now all transcode , my nas CPU goes to 100% and is not possible to see it. I tested more 5he one movies that before worked fine. ffmpeg-transcode-98583ce3-c06b-42c3-826e-c974fba42b08_1.txt embyserver-2.txt ffmpeg-transcode-9778ec74-6a01-415a-afbe-1f60b9ded7c1_1.txt embyserver-1.txt Edited June 23, 2022 by teicang
SamES 1084 Posted June 23, 2022 Posted June 23, 2022 Ok, that was my concern. Was there a remux log as well?
teicang 34 Posted June 24, 2022 Posted June 24, 2022 Hi Sam , the log should be this one .Let me know if you need I maintain this version (you need to make some other test or adjustment,) or if there are't anything you can do and therefore I downgrade the server to previous release were all seems to work fine for me \Gianni ffmpeg-remux-f013196d-1bc2-4966-8189-7fc02477b334_1.txt
SamES 1084 Posted June 24, 2022 Posted June 24, 2022 Thanks, I'll take a look at it to see what might be the issue.
teicang 34 Posted June 24, 2022 Posted June 24, 2022 4 hours ago, SamES said: Thanks, I'll take a look at it to see what might be the issue. Hi Sam, I hope you will find a sot of fix also in the new server release because I tryed to downgrade loading back the 4.6 version (I also tryed to unistall it before,) but I failed , after the istallation, server start but after few second goes in stop . I suppose when I put the new 4.7 release that has changed something and now is anymore possible to change back. I suppose to make that I need to delete all the file present in the NAS but in this way I wil lloose all my customization
SamES 1084 Posted June 24, 2022 Posted June 24, 2022 Yeah, going back, especially from a major release (4.7 -> 4.6) would not be advisable. If we need to go back then I can revert something in the client that will stop the transcoding but will still give you have the same experience you had when it was working with 4.6. Can you give me a day or two to check something? In the meantime you can probably find the 4.6 portable version and setup a temporary server with it if your desperate to get something working, or manually switch the tracks so that the audio track is the primary and it directPlays
teicang 34 Posted June 24, 2022 Posted June 24, 2022 1 hour ago, SamES said: Can you give me a day or two to check something? yes sure my friend good night
teicang 34 Posted June 27, 2022 Posted June 27, 2022 Hi Sam$Frost, could you confirm me that also if I select the First audio track but this is in DTS the system transcode it ? I'm noticed this behaviour on movies before sure works ( for 4k movies I'm be able to see just with direct play , if trascoding my CPU goes to 100% and movies blocked ). Thx
FrostByte 5453 Posted June 27, 2022 Posted June 27, 2022 1 hour ago, teicang said: Hi Sam$Frost, could you confirm me that also if I select the First audio track but this is in DTS the system transcode it ? I'm noticed this behaviour on movies before sure works ( for 4k movies I'm be able to see just with direct play , if trascoding my CPU goes to 100% and movies blocked ). Thx Yes, Samsung dropped DTS support on all TVs in 2018. If you check the back of your user's manual you should see a table with all the audio types supported. If you do try and play DTS Emby will then convert the DTS to AC3 and remux your file. You should always pre-select an audio format which is compatible so you don't have to remux. Conversion is there when needed. For best results though getting something like a Shield Pro and plugging it into the HDMI input port of a soundbar would be best. Then you wouldn't be limited by the audio formats of what your TV supports. 1
SamES 1084 Posted June 27, 2022 Posted June 27, 2022 1 hour ago, teicang said: Hi Sam$Frost, could you confirm me that also if I select the First audio track but this is in DTS the system transcode it ? I'm noticed this behaviour on movies before sure works ( for 4k movies I'm be able to see just with direct play , if trascoding my CPU goes to 100% and movies blocked ). Thx Yes, that is probably true. Your TV doesn't support DTS, so it needs to convert the audio. However, due to the recent change, DirectStream is probably failing, so it then transcodes. I think for now I'll revert one change which will make it work like it did just before you did the server upgrade. 2
SamES 1084 Posted June 29, 2022 Posted June 29, 2022 On 16/06/2022 at 21:33, SamES said: Thanks for trying the firmware update. It's good to see that Samsung are still releasing these for your model, so with some hope they may fix this issue one day. Response today from Samsung: Quote The sample app you provided was checked by higher ranked engineers. The issue is fixed with a patch containing may bugfixes that it's going to be evetually released as an update on the TVs. At this moment we are still trying to inquiry when this update will be available. and now we wait... Please let me know if you see new firmware updates for your TV, then we will have to work out how to test this. 2 1
