nbedendo 4 Posted October 16, 2021 Posted October 16, 2021 Last week i was in working trip so i used a lot Emby with the iOS app so i discover some fix to think about. I use a lot the FOLDER VIEW some some Library and if i change the setting on the VIEW to LIST as example this do not apply to all the subfolder... this happen also on the WEBAPP, i think that will be usefull set the same view automatically for all the subdir and than change if you need in some of that and not the opposite like now. Thought?
Happy2Play 9811 Posted October 16, 2021 Posted October 16, 2021 There are several topics for this, but currently not possible. Pretty sure this would fall under this request. Save View for all Subfolder's - Feature Requests - Emby Community
nbedendo 4 Posted October 16, 2021 Author Posted October 16, 2021 Sorry, i used the search before to create the post but probably with wrong keyword, Yes fall under the suggested post. And in any case tnx for let me know that is not possible i will do manually instead of waiting
