Ammar21 0 Posted October 15, 2021 Posted October 15, 2021 So I have some TV Shows that have chapters which skip the intros, how can I use them?
Luke 42241 Posted October 15, 2021 Posted October 15, 2021 Hi there, what version of the emby Samsung app do you have?
Ammar21 0 Posted October 15, 2021 Author Posted October 15, 2021 23 minutes ago, Luke said: Hi there, what version of the emby Samsung app do you have? It's 0.122
Luke 42241 Posted October 15, 2021 Posted October 15, 2021 Ok unfortunately we can't update that app anymore as Samsung is no longer accepting updates for older models. So you can't use chapters during playback but it does support chapters prior to playback on the video detail screen. Essentially you can select a chapter to start the movie right from that point.
Ammar21 0 Posted October 15, 2021 Author Posted October 15, 2021 15 minutes ago, Luke said: Ok unfortunately we can't update that app anymore as Samsung is no longer accepting updates for older models. So you can't use chapters during playback but it does support chapters prior to playback on the video detail screen. Essentially you can select a chapter to start the movie right from that point. Thanks
