Luke 42239 Posted March 19, 2022 Posted March 19, 2022 9 hours ago, brainfryd said: @emveepee Hi Martin - Is there a new version of this plugin or any way to get the link published again as it doesn't seem to be working. I'm having an issue my emby server crashing on latest update and suspect it may be related to my old version of the nextpvr plugin V3.70 Thanks for your help Sounds like you're on the beta server. Please see here: Thanks.
brainfryd 7 Posted March 20, 2022 Posted March 20, 2022 @emveepee Thanks for your response, Martin. Yes as you surmised, I am running the Beta version of the server and have been for years... this is disappointing, as I've been a user & supporter of Emby, since about 2009 in its previous life, but it has been on the cards for a while. I have to admit, I'm not sure Emby will ever get to supporting the Dvico DVB-T quad HD tuner that was available for a long time here in Aust, it appears unless you purchase a brand like Hauppauge, support for tuners is likely to be limited. I for one really appreciate your support of the plug-in over it's history as I've also used NextPVR for quite some time and been very happy with performance and support. I guess I will investigate the m3u tuner option although I am hesitant to go this way Again thanks for all your help and support on this plugin and NextPVR community in general
sub3 64 Posted March 21, 2022 Posted March 21, 2022 (edited) We are trying to arrange for an updated NextPVR plugin compatible with these recent Emby changes. Hopefully we'll be able to have something up an running in the near future. It wont provide the same functionality, but will fit in with Emby's new model. Edited March 21, 2022 by sub3 2
cselvaraj 0 Posted March 22, 2022 Posted March 22, 2022 Hello, Martin. The download link no longer works. Is it still possible to get version 3.7.5 of this plugin? Thank you! Emby version: 4.6.7.0 NextPVR version: 5.2.6.220206
emveepee 133 Posted March 22, 2022 Author Posted March 22, 2022 As l noted above I removed the addon to avoid confusion because when Emby 4.7 is released you will lose access to recordings and will also need to migrate your schedules. Even if Emby updates the plugin this will be a necessary. Personally I recommend considering using the m3u tuner. Martin
Luke 42239 Posted March 22, 2022 Posted March 22, 2022 The plugin should be available again soon and you'll be able to set it up using the process outlined here: Thanks.
arrbee99 1836 Posted March 22, 2022 Posted March 22, 2022 So to clarify, this plugin means you have to control / record / whatever through Emby alone ? But it does take the guide data from NextPVR ? I think it does for me, at lease I have duplicate channels via the m3u and the plugin and the guides have different sources and are slightly different. Or maybe I need to update the older guide. My guide from NextPVR is OTA and m3u is xmltv by the way.
emveepee 133 Posted March 22, 2022 Author Posted March 22, 2022 Emby and NextPVR are isolated so while they can still work separately it could be a nightmare to manage. NextPVR recordings will also have priority over streaming to Emby since that to NextPVR is live TV Martin 1
cselvaraj 0 Posted April 8, 2022 Posted April 8, 2022 On 3/22/2022 at 2:10 PM, emveepee said: As l noted above I removed the addon to avoid confusion because when Emby 4.7 is released you will lose access to recordings and will also need to migrate your schedules. Even if Emby updates the plugin this will be a necessary. Personally I recommend considering using the m3u tuner. Martin I understand the coming change. I made the mistake of uninstalling the current plugin and lost the existing functionality. I was hoping to restore it by reinstalling the current version of the plugin. At any rate, it's not a big deal. I can wait for the next versions and the new setup they represent. Thanks!
emveepee 133 Posted April 8, 2022 Author Posted April 8, 2022 6 hours ago, cselvaraj said: I understand the coming change. I made the mistake of uninstalling the current plugin and lost the existing functionality. I was hoping to restore it by reinstalling the current version of the plugin. At any rate, it's not a big deal. I can wait for the next versions and the new setup they represent. Thanks! Ok I reverted the delete on github for those that want to continue to use this before 4.7 comes out. Martin
cselvaraj 0 Posted April 9, 2022 Posted April 9, 2022 On 4/8/2022 at 9:35 AM, emveepee said: Ok I reverted the delete on github for those that want to continue to use this before 4.7 comes out. Martin That's great! Thanks so much, Martin!
