deallier 8 Posted October 14, 2021 Posted October 14, 2021 Hi i just upgraded the two e5-2620 v4 for two E5-2698 v4 and restarted the server and now i have No compatible streams are currently available but only on live tv i checked and all the streams are fine though VLC player here is the server log embyserver.txt and hardware detection any help would be great thanks hardware_detection-63769812755.txt
Luke 42197 Posted October 14, 2021 Posted October 14, 2021 Hi, looks like you configured one or more custom folders for certain functions and now your K: drive has gone missing: 2021-10-14 12:52:30.685 Error FfmpegManager: Error updating ffmpeg validator cache *** Error Report *** Version: 4.6.4.0 Command line: C:\Users\admin-dea\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 6.1.7601 Service Pack 1 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/admin-dea/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 40 Data path: C:\Users\admin-dea\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\admin-dea\AppData\Roaming\Emby-Server\system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path 'k:\Cache\cache\ffmpeg'. at System.IO.FileSystem.CreateDirectory(String fullPath, Byte[] securityDescriptor) at System.IO.Directory.CreateDirectory(String path) at Emby.Server.Implementations.IO.ManagedFileSystem.CreateDirectory(String path) at Emby.Server.MediaEncoding.Unified.Ffmpeg.Capabilities.FfmpegValidator.GetCapabilities(String option, CapabilityParserBase parser, FfmpegCapabilities caps, Boolean skipCache, CancellationToken cancellationToken) Source: System.IO.FileSystem TargetSite: Void CreateDirectory(System.String, Byte[])
deallier 8 Posted October 14, 2021 Author Posted October 14, 2021 Hi luke thanks for the reply yes i found that out about 10 min after posting this all sorted now thank you again 1
