paddy75 16 Posted September 17, 2023 Posted September 17, 2023 (edited) have less time at the moment to check it in detail. hope the next week i can look about it. i tried a lot about the drivers. uninstall, reinstall also opened a ticket by qnap to look about it. they created another container caffee and after this the nvidia-uvm was present. after a reboot the file was not there again and they created a caffe-2 container and then the file was there again. the support do not really care when it is a kind of 3th party app and not a qnap application. i did not run the command in the cli directly. when it works with it, then i think i have a workaround without a autorun.sh Edited September 17, 2023 by paddy75
Luke 42239 Posted September 18, 2023 Posted September 18, 2023 On 9/17/2023 at 12:16 AM, paddy75 said: have less time at the moment to check it in detail. hope the next week i can look about it. i tried a lot about the drivers. uninstall, reinstall also opened a ticket by qnap to look about it. they created another container caffee and after this the nvidia-uvm was present. after a reboot the file was not there again and they created a caffe-2 container and then the file was there again. the support do not really care when it is a kind of 3th party app and not a qnap application. i did not run the command in the cli directly. when it works with it, then i think i have a workaround without a autorun.sh That would be great, thanks !
Ikario 39 Posted September 19, 2023 Author Posted September 19, 2023 So yeah, the issue is that you need QuTS to call the GPU at least once before the emby container is ran, for some reason depending on how you run your containers that may or may not happen, it's a whole mess. Running that command is just one surefire way of making it appear. You can then use an autorun.sh or whatever floats your boat. Hell, there's probably something on QuTS Hero you could run on boot that will make it appear as a workaround. Also, if you run your containers manually, you don't need to create an autorun, there's tons of ways you could go around it. The autorun proposed is a solution for people that run their containers on boot and want to have everything heavily automated, it makes sense when you also run your containers using docker compose using a script, but there's plenty of solutions to this same problem. 1
lswang168 0 Posted May 26, 2024 Posted May 26, 2024 It seems that Qnap updated there nvidia driver, and not recognized by Emby server now. below docker compose file was working and containers can start and with hw acceleration, but now the hardware acceleraiton device list is gone. Qnap: Ts-873a, added 1050 graphic card version of Qnap nvkerneldriver: 5.17; installed latest GPU driver also. After recent qnap updates, this happed, we didn't rebuild the emby server. Current dock compose file: version: '3.6' services: emby: build: dockerfile: /share/Container/jellyfin8/Dockerfile context: /share/CACHEDEV2_DATA/.qpkg/NVIDIA_GPU_DRV/usr container_name: emby2 environment: PUID: 1000 PGID: 1000 GIDLIST: 0 TZ: Asia/Shanghai volumes: - /share/Container/jellyfin8/docker/config/emby:/config - /share/Cinema:/media - /share/PT:/media2 - type: tmpfs target: /scratch tmpfs: size: 10000000000 - /share/Container/jellyfin8/media/scratch:/scratch ports: - '8096:8096' # HTTP port - '8920:8920' # HTTPS port - '7359:7359' - '1900:1900' devices: - /dev/nvidia0 - /dev/nvidiactl - /dev/nvidia-uvm restart: unless-stopped image: embyhwtrc network_mode: bridge and enter SSH, use: docker compose up --build -d to build up. but, if change to jellyfin, it works and can use hw acceration: version: '3.6' services: jellyfin: build: dockerfile: /share/Container/jellyfin2/Dockerfile context: /share/CACHEDEV2_DATA/.qpkg/NVIDIA_GPU_DRV/usr container_name: jellyfin2 environment: PUID: 1000 PGID: 1000 GIDLIST: 0 TZ: Aisa/Shanghai volumes: - /share/Container/jellyfin2/config:/config - /share/Container/jellyfin2/scratch:/scratch - /share/Container/jellyfin2/transcode:/transcode - /share/Cinema:/media - /share/PT:/media2 - type: tmpfs target: /scratch tmpfs: size: 10000000000 - /share/Container/jellyfin2/media/scratch:/scratch ports: - '8097:8096' - '8921:8920' devices: - /dev/nvidia0 - /dev/nvidiactl - /dev/nvidia-uvm restart: unless-stopped image: jellyfinhwtrc network_mode: bridge so don't know how to solve emby sever hw acceleration problem. Wonder anyone facing the similar problem? pls share experience on how to solve it, thank you.
lswang168 0 Posted May 26, 2024 Posted May 26, 2024 3 hours ago, lswang168 said: It seems that Qnap updated there nvidia driver, and not recognized by Emby server now. below docker compose file was working and containers can start and with hw acceleration, but now the hardware acceleraiton device list is gone. Qnap: Ts-873a, added 1050 graphic card version of Qnap nvkerneldriver: 5.17; installed latest GPU driver also. After recent qnap updates, this happed, we didn't rebuild the emby server. Current dock compose file: version: '3.6' services: emby: build: dockerfile: /share/Container/jellyfin8/Dockerfile context: /share/CACHEDEV2_DATA/.qpkg/NVIDIA_GPU_DRV/usr container_name: emby2 environment: PUID: 1000 PGID: 1000 GIDLIST: 0 TZ: Asia/Shanghai volumes: - /share/Container/jellyfin8/docker/config/emby:/config - /share/Cinema:/media - /share/PT:/media2 - type: tmpfs target: /scratch tmpfs: size: 10000000000 - /share/Container/jellyfin8/media/scratch:/scratch ports: - '8096:8096' # HTTP port - '8920:8920' # HTTPS port - '7359:7359' - '1900:1900' devices: - /dev/nvidia0 - /dev/nvidiactl - /dev/nvidia-uvm restart: unless-stopped image: embyhwtrc network_mode: bridge and enter SSH, use: docker compose up --build -d to build up. but, if change to jellyfin, it works and can use hw acceration: version: '3.6' services: jellyfin: build: dockerfile: /share/Container/jellyfin2/Dockerfile context: /share/CACHEDEV2_DATA/.qpkg/NVIDIA_GPU_DRV/usr container_name: jellyfin2 environment: PUID: 1000 PGID: 1000 GIDLIST: 0 TZ: Aisa/Shanghai volumes: - /share/Container/jellyfin2/config:/config - /share/Container/jellyfin2/scratch:/scratch - /share/Container/jellyfin2/transcode:/transcode - /share/Cinema:/media - /share/PT:/media2 - type: tmpfs target: /scratch tmpfs: size: 10000000000 - /share/Container/jellyfin2/media/scratch:/scratch ports: - '8097:8096' - '8921:8920' devices: - /dev/nvidia0 - /dev/nvidiactl - /dev/nvidia-uvm restart: unless-stopped image: jellyfinhwtrc network_mode: bridge so don't know how to solve emby sever hw acceleration problem. Wonder anyone facing the similar problem? pls share experience on how to solve it, thank you. solve it by add permissions: # chmod 666 /dev/nvidia0 # chmod 666 /dev/nvidiactl # chmod 666 /dev/nvidia-uvm
Ikario 39 Posted May 27, 2024 Author Posted May 27, 2024 11 hours ago, lswang168 said: solve it by add permissions: # chmod 666 /dev/nvidia0 # chmod 666 /dev/nvidiactl # chmod 666 /dev/nvidia-uvm Yeah, latest update breaks my solution in the same way QuickSync was broken before, and technically your solution works. HOWEVER, I'd advise that, if you have properly managed user/groups, to do chmod 770 /dev/nvidia0 && chmod 770 /dev/nvidiactl && chmod 770 /dev/nvidia-uvm instead.
