GiGo 108 Posted October 12, 2021 Posted October 12, 2021 (edited) I'm not sure how popular retro gaming is on these boards, but Batocera is a bit like Retro Pie, for anyone that doesn't know. In the last two versions v31 and v32 they have added the ability to install Flatpak packages, so I have installed the beta version. However it appears there is an issue with generating a PIN to use for emby connect, it just refused to generate a Key. No issue for me but just wanted to know if this is an issue for any other Flatpak users? Also just noticed a Javascript Error when selecting Shutdown from the menu, screen shot attached. EDIT: Using the 3.0.15 x64 version Edited October 12, 2021 by GiGo
Luke 42246 Posted October 24, 2021 Posted October 24, 2021 HI, are you still unable to generate an Emby Connect pin code?
GiGo 108 Posted October 24, 2021 Author Posted October 24, 2021 9 minutes ago, Luke said: HI, are you still unable to generate an Emby Connect pin code? All sorted now with the pin code. Not sure what went wrong but reinstalled and worked. However 'shutdown' doesn't work. I assume its to do with it not calling the correct command for the Batocera system. Also noticed that Logo as Title is enabled on the Emby Theatre Flatpak
Luke 42246 Posted October 24, 2021 Posted October 24, 2021 We'll take a look at the shutdown. Thanks.
