Dizzy49 99 Posted October 12, 2021 Posted October 12, 2021 Now that I know it is actually doing something I'm just going to let it run. One way or another I need/want all the images and metadata so I might as well just let it go. @Luke I will give that a try once the scan is completed. At the rate it's going, it should be done tomorrow morning. Right now the scan is in the N's in my shows. My Auto Organize doesn't seem to be working. I tried a show in the D's and I selected the Series, but I keep getting the NULL back when I try. I tried several different shows and I keep getting the same thing. The D one is a new show, but several of the others are not new shows. A couple did work, but it is hit or miss with the existing shows, and just doesn't work at all for newer shows.
Luke 42198 Posted October 12, 2021 Posted October 12, 2021 Hi there @Dizzy49. Let's look at an example: Thanks.
Dizzy49 99 Posted October 12, 2021 Author Posted October 12, 2021 Looks like the scan needed to complete fully before it would work properly. Now I'm just back to fighting with Anime episodes.
