chrismallia 12 Posted October 11, 2021 Posted October 11, 2021 Hi Im getting a problem with the android mobile APP only, the problem is when the app uses the reverse proxy it crashes several time while playing a video, the media starts but after a few seconds the pic freezes and the screen goes black, if I close the app it remains in the mobiles notification menu, so I would have to force close it, another way to get it working is when it freezes I switchh to mobile data and back to wifi, this does not seam to happen when bypassing the reverse proxy, but the problem is not the reverse proxy as all other devices work fine INCLUDING the web browser on the same mobile phone. its just the app. I tried the lates beta with same problem. Here are the server logs, embyserver.txt
chrismallia 12 Posted October 11, 2021 Author Posted October 11, 2021 2 minutes ago, Luke said: Hi, what reverse proxy are you using? Nginx
Luke 42243 Posted October 11, 2021 Posted October 11, 2021 OK, i would suggest comparing your nginx configuration to that of @pir8radio. Please let us know if that helps. Thanks.
chrismallia 12 Posted October 12, 2021 Author Posted October 12, 2021 18 hours ago, Luke said: OK, i would suggest comparing your nginx configuration to that of @pir8radio. Please let us know if that helps. Thanks. I am using swag docker by linuxserver.io. I dont think there is a problem with the reverse proxy cos all other apps and browsers work fine , could I be mistaken? it only the android mob app, and it happens randomly . sometimes I can re produce it by stopping the movie and hitting play from the info page of the movie/tv show.
Luke 42243 Posted October 12, 2021 Posted October 12, 2021 Yes you could be mistaken. Did you compare your nginx config to his?
chrismallia 12 Posted October 12, 2021 Author Posted October 12, 2021 @Luke I resolved it. As my emby server runs in docker it was advertising the docker's bridged network of 172 to the devices, I enterd the local server ip in network setting (local ip adress) and everything is fine now, funny this only affected the mobile app. As I always say , you guys rock
Luke 42243 Posted October 12, 2021 Posted October 12, 2021 Usually the server network settings are a last resort, more of a workaround to handle extreme corner cases. You're better configuring the network connection of the docker container such that it works without having to use the server network settings. 1
chrismallia 12 Posted October 13, 2021 Author Posted October 13, 2021 @Luke Thanks a lot, you made me think, so I went to my docker configuration and realized that the docker network I created was not a bridge network, (I forgot to create it as bridge), I re created the docker network removed the server IP from emby server and all is great. Thank you again
