crusher11 1150 Posted November 8, 2021 Author Posted November 8, 2021 So I guess I'm just screwed, then?
Happy2Play 9814 Posted November 16, 2021 Posted November 16, 2021 The plugin is doing what it is suppose to as a backdrop must be textless ie NULL backbrops. Will have to see if the same can be done for TVDB backdrops also. This is a provider defect. Only change that will eventually happen is the addition to text based backdrops to Thump/landscape. No need to bump a topic where the provider is the issue and we are correcting that issue. 1
crusher11 1150 Posted November 16, 2021 Author Posted November 16, 2021 Removing images that were previously accessible is not fixing an issue.
GrimReaper 4912 Posted November 16, 2021 Posted November 16, 2021 Just now, crusher11 said: Removing images that were previously accessible is not fixing an issue. It actually is. 1
crusher11 1150 Posted November 16, 2021 Author Posted November 16, 2021 Just now, GrimReaper said: It actually is. No it isn't. The issue could have been fixed simply by not selecting them as the default. Alternatively, moving them to the Thumbs section. Removing them completely just makes it significantly harder to use them as thumbs, or to use them in instances where there are no alternatives. Previously, you always had the option not to use those images. Now, there's no way to use them whether you want to or not, as backdrops or otherwise.
Happy2Play 9814 Posted November 16, 2021 Posted November 16, 2021 The issue is previously was wrong so that defect was corrected. So reinstating defects will get just as much pushback. Text base backdrops should always be excluded for the backdrops section. 1
Luke 42255 Posted November 16, 2021 Posted November 16, 2021 Yes now we need to make the text ones available as thumbs.
crusher11 1150 Posted November 17, 2021 Author Posted November 17, 2021 8 hours ago, Happy2Play said: The issue is previously was wrong so that defect was corrected. So reinstating defects will get just as much pushback. Text base backdrops should always be excluded for the backdrops section. How is it a defect? You can always choose not to use them. I frequently grabbed them to use as thumbs. Now, that's not an option.
Luke 42255 Posted November 17, 2021 Posted November 17, 2021 The same list that you see in the manual image editor is what the automatic downloader uses as well.
GrimReaper 4912 Posted November 17, 2021 Posted November 17, 2021 3 minutes ago, crusher11 said: I frequently grabbed them to use as thumbs. Now, that's not an option. Add image by URL.
crusher11 1150 Posted November 17, 2021 Author Posted November 17, 2021 Previously: hit the magnifying glass, look at what's available, download, resize, add. Now: Go to TMDB, type in the name, click on it, hover over "media", select "backdrops", look at what's available, download, resize, add. This is a colossal waste of time if it turns out there aren't any, which is frequently the case.
crusher11 1150 Posted November 24, 2021 Author Posted November 24, 2021 So...are we ever going to get these images added as thumbs, or something? I don't understand why you would just remove a whole lot of images from access in Emby, and then leave it like that.
Luke 42255 Posted November 24, 2021 Posted November 24, 2021 On 11/16/2021 at 5:05 PM, Luke said: Yes now we need to make the text ones available as thumbs.
crusher11 1150 Posted November 25, 2021 Author Posted November 25, 2021 But when is that going to happen? It's been over a month since they were removed. I really need to restart my server but I can't because I'll lose access to them when this plug in updates.
crusher11 1150 Posted December 6, 2021 Author Posted December 6, 2021 Why would you not have it sorted before removing the images from the backdrops section? I'm currently unable to reboot my server because I'll lose access to all those images if I do.
crusher11 1150 Posted January 1, 2022 Author Posted January 1, 2022 On 12/5/2021 at 6:43 PM, Luke said: HI, yes it's on the to do list. thanks. It's been three months since you removed those image types from backdrops. They still haven't been added to thumbs. Why would you not do both at the same time? This change is great for people who just want to add movies and have Emby take care of everything, but it's a massive pain if you're actually manually setting up your artwork.
crusher11 1150 Posted January 5, 2022 Author Posted January 5, 2022 I've now been forced to restart my server, so I no longer have access to images I can quickly use to create thumbnails. This really should have all been done in one go.
