rodainas 191 Posted June 26, 2021 Posted June 26, 2021 (edited) Hi @TeamB , I have a question: Its possible for you to add on the "Next Up" lists, a partially played first episode of any given tvshow and partially played special independently if it has displayseason displayepisode? (I ask because it will be more similar to what emby shows on the "Continue Watching" home section). Images to clear things up: "Continue Watching" on emby web client: The items in question here are: Loki S1 E1 = partially played and first episode from tv show Attack on Titan Special = partially played special with no displayseason displayepisode tag The "Next Up" List from embycon: The workaround to have them show up on my kodi homescreen was adding the "In Progress Episodes" list as a widget, but then I have any other partially played item there that is not a first episode or a special like a real next up episode, so it can be redundant/repetitive. Edited June 26, 2021 by rodainas
TeamB 2440 Posted June 27, 2021 Posted June 27, 2021 12 hours ago, rodainas said: Hi @TeamB , I have a question: Its possible for you to add on the "Next Up" lists, a partially played first episode of any given tvshow and partially played special independently if it has displayseason displayepisode? (I ask because it will be more similar to what emby shows on the "Continue Watching" home section). Images to clear things up: "Continue Watching" on emby web client: The items in question here are: Loki S1 E1 = partially played and first episode from tv show Attack on Titan Special = partially played special with no displayseason displayepisode tag The "Next Up" List from embycon: The workaround to have them show up on my kodi homescreen was adding the "In Progress Episodes" list as a widget, but then I have any other partially played item there that is not a first episode or a special like a real next up episode, so it can be redundant/repetitive. It looks like the Emby Web client has switch to using a brand new API endpoint: /emby/Users/{user_id}/Items/Resume EmbyCon does not use this at all. I think this all goes back to this discussion here: https://emby.media/community/index.php?/topic/93221-4609-merging-continue-watching-next-up/ There was a lot of back and forward with that topic, I asked in the thread if this meant clients would need to change but got no response. The current way it works in EmbyCon is the way it always has, I am not sure I want to change it to be honest as change usually causes more problems than it is worth and I am used to it the way it is now. I may add a custom node creation tool to allow people to add their own filtering/sorting etc for custom widgets, I will look into this and see if this sort of thing would help in this situation. Being able to create you own widget query to the server specifying your own criteria might solve this for uses with specific needs. 1
rodainas 191 Posted June 27, 2021 Author Posted June 27, 2021 1 hour ago, TeamB said: It looks like the Emby Web client has switch to using a brand new API endpoint: /emby/Users/{user_id}/Items/Resume EmbyCon does not use this at all. I think this all goes back to this discussion here: https://emby.media/community/index.php?/topic/93221-4609-merging-continue-watching-next-up/ There was a lot of back and forward with that topic, I asked in the thread if this meant clients would need to change but got no response. The current way it works in EmbyCon is the way it always has, I am not sure I want to change it to be honest as change usually causes more problems than it is worth and I am used to it the way it is now. I may add a custom node creation tool to allow people to add their own filtering/sorting etc for custom widgets, I will look into this and see if this sort of thing would help in this situation. Being able to create you own widget query to the server specifying your own criteria might solve this for uses with specific needs. Thank you for the clear explanation, really appreciate it.
Zodler 18 Posted October 10, 2021 Posted October 10, 2021 On 6/26/2021 at 4:39 PM, rodainas said: Hi @TeamB , I have a question: Its possible for you to add on the "Next Up" lists, a partially played first episode of any given tvshow and partially played special independently if it has displayseason displayepisode? (I ask because it will be more similar to what emby shows on the "Continue Watching" home section). I think it is better the way it already is. It is a lot better to have separate In Progress and Next Up and not mix them up. It is cleaner and more useful. There is one thing missing is an In Progress Media for Movies and TV Episodes combined. Can I make this myself?
rodainas 191 Posted October 10, 2021 Author Posted October 10, 2021 3 hours ago, Zodler said: I think it is better the way it already is. It is a lot better to have separate In Progress and Next Up and not mix them up. It is cleaner and more useful. There is one thing missing is an In Progress Media for Movies and TV Episodes combined. Can I make this myself? Sure, but they are not exactly separate, the Next Up list as it is already indicates if the episode on that list is partially played (as in progress), if you partially play any episode that is already on that list, kodi will give you an in progress tag indicator and kodi will ask if you want to resume or start from 0, so basically the Next Up works as in progress too for every episode except those 2 scenarios: First Episode of a Series or a Special episodes. The idea was from a widget point of view having the option to use less helps with low performance devices as firestick for example. But I understand the reason TeamB didnt want to change it. As far as I know Kodi wont allow mixing on the same list episodes and movies.
TeamB 2440 Posted October 10, 2021 Posted October 10, 2021 9 minutes ago, rodainas said: As far as I know Kodi wont allow mixing on the same list episodes and movies. yes this, Kodi does not really have any concept of mixed types in the same list, it is designed to show a list of items of a particular type.
Zodler 18 Posted October 10, 2021 Posted October 10, 2021 But it does have it. I have used it for many years. I have Emby For Kodi Next Gen and sync with the Kodi Library. There is a node called In Progress Media that shows both movies and tv episodes in progress. I don't know it comes with what, when I install Titan skin it is available. Maybe it is in skin helper addon.
TeamB 2440 Posted October 10, 2021 Posted October 10, 2021 (edited) it works with all skins? Like the default skin? Edited October 10, 2021 by TeamB
Zodler 18 Posted October 10, 2021 Posted October 10, 2021 Yes. I will take a screenshot and see where it is and post it here later.
TeamB 2440 Posted October 10, 2021 Posted October 10, 2021 (edited) I have added the ability to the custom node creator in EmbyCon to have multiple types. you can set up a custom note that has Movies, Episodes in progress. This is in the latest beta for both Krypton (18) and Matrix (19) Edited October 10, 2021 by TeamB 1
Zodler 18 Posted October 11, 2021 Posted October 11, 2021 Thank you. I just tested it and it works. It's so essential. In the Edit Node I have to set Recursive to true to see the results. Otherwise it shows all the items. Why is that and what is the use case to set Recursive to false? Also at the bottom there are 3 separate lines, what they do? You can use only one for Kodi Media Type and I set it to tvshows and couldn't clear it but the node still works and shows the In progress episodes and movies.
TeamB 2440 Posted October 11, 2021 Posted October 11, 2021 3 hours ago, Zodler said: Thank you. I just tested it and it works. It's so essential. One persons essential is another persons meh 4 hours ago, Zodler said: In the Edit Node I have to set Recursive to true to see the results. Otherwise it shows all the items. Why is that and what is the use case to set Recursive to false? The custom node builds an emby query, check the swager api for the exact reference but recursive just means search all the things through all child paths, if no parent is set it searches every path for items. 4 hours ago, Zodler said: Also at the bottom there are 3 separate lines, what they do? You can use only one for Kodi Media Type and I set it to tvshows and couldn't clear it but the node still works and shows the In progress episodes and movies. I mentioned this before, kodi does not have a concept of mixed items, setting the type lets the skin and view know what sort of items to display as each item type in kodi has slightly different listitem values, i.e a movie does not have season info. This lets the skin and view know how to display items correctly.
Zodler 18 Posted October 12, 2021 Posted October 12, 2021 14 hours ago, TeamB said: One persons essential is another persons meh Seriously? In Progress is a no-brainer. Every streaming app Disney, Netflix..... shows the stuff you are currently watching. So it's nothing extraordinary. It is common sense. It is as basic as it gets.
TeamB 2440 Posted October 12, 2021 Posted October 12, 2021 Combined movie/episode in progress is not something i would ever use so yeah seriously.
