SamES 1084 Posted October 25, 2021 Posted October 25, 2021 On 15/10/2021 at 05:17, cr4shrid3 said: Any news or ideas? Im not even able to download the app from the Uk app store (code 205). Samsung is disgusting @cr4shrid3, can you please share more details about the TV model code? (you can find it on Settings/Support/About this TV). Can you also please share a screenshot of the error? Thanks
cr4shrid3 3 Posted October 27, 2021 Author Posted October 27, 2021 @SamES Modelcode: UE55JS9090 Softwareversion: T-HKPDEUC-1570.0 1
SamES 1084 Posted October 27, 2021 Posted October 27, 2021 2 hours ago, cr4shrid3 said: Modelcode: UE55JS9090 Softwareversion: T-HKPDEUC-1570.0 Thanks, can you also post a picture of the error when trying to install from the store?
SamES 1084 Posted November 3, 2021 Posted November 3, 2021 On 28/10/2021 at 08:06, SamES said: Thanks, can you also post a picture of the error when trying to install from the store? @cr4shrid3can you please post a picture of the error you get when you try and install from the app store? Thanks
cr4shrid3 3 Posted November 3, 2021 Author Posted November 3, 2021 (edited) @SamES sorry no time till now Edited November 3, 2021 by cr4shrid3 1
SamES 1084 Posted November 23, 2021 Posted November 23, 2021 Is this still a problem? Can you install from the store now? Do you have any ad-blockers, reverse proxies or other 'complex' network setups?
cr4shrid3 3 Posted November 23, 2021 Author Posted November 23, 2021 Hi, yes it is still actual. Usb doesnt work. Store was not tested again. Regarding network topology, Screen is directly connected to router, without any VPNs nor blockers.
SamES 1084 Posted November 23, 2021 Posted November 23, 2021 And for good measure I would do a full TV and SmartHub Factory reset.
Luke 42241 Posted December 16, 2021 Posted December 16, 2021 @cr4shrid3 can you please try installing the latest USB version? Thanks !
cr4shrid3 3 Posted December 17, 2021 Author Posted December 17, 2021 Gave it a try, unfortunately it didn't work. Seems like Samsung blocked by TV some kind from installing user apps.
SamES 1084 Posted December 17, 2021 Posted December 17, 2021 On 24/11/2021 at 08:23, SamES said: And for good measure I would do a full TV and SmartHub Factory reset. Did you try this again?
