MattCooksley 1 Posted October 8, 2021 Posted October 8, 2021 (edited) I couldn't connect the server, so I checked my server and it is up and running, so i checked the IP and port, and no connection. I go to my server and check local host and no connection. I try to start emby-server, nothing. I restart my raspberry pi, nothing. Checking the error log, it seems a LoaderException and then instant server shutdown. I dont know what that means. I don't believe I have made any changes on my end nor have I installed any third party plugins (unless that is part of the base install) help? embyserver-63769315090.txt Edited October 8, 2021 by MattCooksley
Happy2Play 9813 Posted October 8, 2021 Posted October 8, 2021 1 minute ago, MattCooksley said: I couldn't connect the server, so I checked my server and it is up and running, so i checked the IP and port, and no connection. I go to my server and check local host and no connection. I try to start emby-server, nothing. I restart my raspberry pi, nothing. Checking the error log, it seems a LoaderException and then instant server shutdown. I dont know what that means. I don't believe I have made any changes on my end help? embyserver-63769315090.txt 14.21 kB · 0 downloads Did you roll back from a beta release? But those load errors are usually from incompatible plugins.
MattCooksley 1 Posted October 9, 2021 Author Posted October 9, 2021 (edited) 4 minutes ago, Happy2Play said: Did you roll back from a beta release? But those load errors are usually from incompatible plugins. No rollback. I haven't touched anything server side since install to my knowledge. Last night I played a video, today is this issue Edited October 9, 2021 by MattCooksley
Happy2Play 9813 Posted October 9, 2021 Posted October 9, 2021 @Lukeis this a corrupt install or just a issue with plugins? 2021-10-08 18:38:10.395 Error Main: Error in appHost.Init *** Error Report *** Version: 4.6.4.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb Operating system: Linux version 5.10.60-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1449 Framework: .NET Core 3.1.13 OS/Process: arm/arm Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.FileLoadException: System.IO.FileLoadException: Could not load file or assembly 'Emby.ProcessRun, Version=4.6.4.0, Culture=neutral, PublicKeyToken=null'. Method signature has invalid calling convention. (0x80131239) File name: 'Emby.ProcessRun, Version=4.6.4.0, Culture=neutral, PublicKeyToken=null' ---> System.Runtime.InteropServices.COMException (0x80131239): Method signature has invalid calling convention. (0x80131239) at Emby.Server.Implementations.ApplicationHost.RegisterResources() at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.HostedService.StartAsync(CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void RegisterResources() InnerException: System.Runtime.InteropServices.COMException: Method signature has invalid calling convention. (0x80131239) Source: TargetSite: 2021-10-08 18:38:10.434 Info Main: Shutdown complete
Luke 42246 Posted October 9, 2021 Posted October 9, 2021 Looks like an incompatible plugin version, although I'm not sure which. Try going here: /var/lib/emby/plugins And deleting all of the dll files. Then start Emby Server and see if that helps. Thanks.
MattCooksley 1 Posted October 9, 2021 Author Posted October 9, 2021 (edited) 8 hours ago, Luke said: Looks like an incompatible plugin version, although I'm not sure which. Try going here: /var/lib/emby/plugins And deleting all of the dll files. Then start Emby Server and see if that helps. Thanks. Hi @Luke I have deleted all the dll files and tried again. Same result. Before deleting them I did notice the Tvdb.dll has a more recent date (10-7-21) than the others (all from September) , so that may be the culprit? Regardless, it still isnt working. I have tried a second time deleting the plugins after they are redownloaded by the server and restarting Edited October 9, 2021 by MattCooksley
Happy2Play 9813 Posted October 9, 2021 Posted October 9, 2021 7 hours ago, MattCooksley said: Hi @Luke I have deleted all the dll files and tried again. Same result. Before deleting them I did notice the Tvdb.dll has a more recent date (10-7-21) than the others (all from September) , so that may be the culprit? Regardless, it still isnt working. I have tried a second time deleting the plugins after they are redownloaded by the server and restarting Sounds like you need to do a reinstall as something is actually corrupted, but that is just a guess. As for the tvdb.dll that was actually just updated.
Luke 42246 Posted October 10, 2021 Posted October 10, 2021 13 hours ago, MattCooksley said: Hi @Luke I have deleted all the dll files and tried again. Same result. Before deleting them I did notice the Tvdb.dll has a more recent date (10-7-21) than the others (all from September) , so that may be the culprit? Regardless, it still isnt working. I have tried a second time deleting the plugins after they are redownloaded by the server and restarting Can you please attach a new server log file? Thanks.
