dml33 26 Posted October 7, 2021 Posted October 7, 2021 (edited) Hi. Since some days ago, I have noticed that movie logos, banners, etc. are not retrieved from fanart.tv. I am using Emby 4.6.4.0 on a FreeBSD NAS. Here is the error: 2021-10-07 18:09:29.596 Info HttpClient: HttpClientManager GET: https://webservice.fanart.tv/v3/movies/36647?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2021-10-07 18:09:29.721 Error HttpClient: Error TrustFailure getting response from *** Error Report *** Version: 4.6.4.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -noautorunwebapp Operating system: Unix 12.2.7.0 Framework: Mono: 5.10.1.57 (5.10.1.57 Tue Jul 6 14:33:15 UTC 2021) OS/Process: X64/X64 Runtime: usr/local/lib/mono/4.5/mscorlib.dll Processor count: 4 Data path: /var/db/emby-server Application path: /usr/local/lib/emby-server/system System.Net.WebException: System.Net.WebException: Error: TrustFailure (One or more errors occurred.) ---> System.AggregateException: One or more errors occurred. ---> System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---> Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED If I go manually to fanart.tv, everything is there. How can I solve it? Thanks! Edited October 12, 2021 by dml33
Luke 42238 Posted November 30, 2021 Posted November 30, 2021 Are you still having an issue with this?
dml33 26 Posted December 1, 2021 Author Posted December 1, 2021 Hi. Well, I am using mono 5.20 with latest beta 4.7.0.18 and fanart.tv works perfectly. With last beta update I did not give even a try to mono 6.8, because it was not working for some Emby versions. Should I have tried? Thanks
Luke 42238 Posted December 1, 2021 Posted December 1, 2021 26 minutes ago, dml33 said: Hi. Well, I am using mono 5.20 with latest beta 4.7.0.18 and fanart.tv works perfectly. With last beta update I did not give even a try to mono 6.8, because it was not working for some Emby versions. Should I have tried? Thanks No, what you're doing is fine. Thanks for the update.
