HawkXP71 112 Posted October 7, 2021 Posted October 7, 2021 DSM 7, Synolology 918+ My libraries dont seem to update when new media is added. Ill drop a couple of new MKV files into appropriate directories, and until I manually "Scan Library Files" the new media isnt picked up. I do have "Enable Real time monitoring" checked. What should I look for in the log file? Or do I need to enable a debug flag to help track this down?
HawkXP71 112 Posted October 7, 2021 Author Posted October 7, 2021 Going through the thread now. Thanks. I followed your thread for migration to DSM 7, this should probably be added to the information there. I am not seeing any inotify type messages in the log, but Ill update the inotify config
HawkXP71 112 Posted October 7, 2021 Author Posted October 7, 2021 I did a reboot of the Emby server (not the NAS box) to confirm I was getting inotify messages, and I was 021-10-07 09:08:06.241 Error LibraryMonitor: Error in Directory watcher for: /volume2/video/Movies *** Error Report *** Version: 4.6.4.0 Command line: /volume2/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build15) (gcc version 7.5.0 (GCC) ) #41890 SMP Thu Jul 15 03:43:42 CST 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: volume2/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume2/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (8192) on the number of inotify watches has been reached, or the operating system failed to allocate a required resource. Source: TargetSite: No Stack Trace Available So I ran $ sudo sysctl -w fs.inotify.max_user_watches=204800 and confirmed the file contains the new number scott@mediabox:/proc/sys/fs/inotify$ cat max_user_watches 204800 I rebooted emby, and no errors Then I touched a mkv and saw the update working. Thanks for all the help. 1
kaj 339 Posted October 7, 2021 Posted October 7, 2021 @HawkXP71 You should make a scheduled task in Synology to do this on every reboot (of the NAS, not Emby), then you shouldn't encounter any problems in the future 1
HawkXP71 112 Posted October 7, 2021 Author Posted October 7, 2021 Just now, kaj said: @HawkXP71 You should make a scheduled task in Synology to do this on every reboot (of the NAS, not Emby), then you shouldn't encounter any problems in the future That is exactly what i did once I confirmed it worked. 2
Ninko 78 Posted October 17, 2021 Posted October 17, 2021 Might seem a silly question, but isn't this something that should be fixed within emby?
Happy2Play 9812 Posted October 17, 2021 Posted October 17, 2021 2 minutes ago, Ninko said: Might seem a silly question, but isn't this something that should be fixed within emby? But it is a platform/OS issue not a Emby issue. I guess in theory Emby could script update inotify for you but I don't believe Emby should be modifying system files like this. 1
Ninko 78 Posted October 17, 2021 Posted October 17, 2021 Oh right ok, didn't know that. Is this a bug that was introduced in DSM 7.0 or was it always there?
Happy2Play 9812 Posted October 17, 2021 Posted October 17, 2021 1 minute ago, Ninko said: Oh right ok, didn't know that. Is this a bug that was introduced in DSM 7.0 or was it always there? No it has always existed in I believe all Linux/MacOS platforms. It is just these standards inotify values are not large enough.
Ninko 78 Posted October 17, 2021 Posted October 17, 2021 If I was to turn real time monitoring off in emby would that stop the errors in the log? I assume the scheduled task of scanning media library would continue working?
Happy2Play 9812 Posted October 17, 2021 Posted October 17, 2021 Just now, Ninko said: If I was to turn real time monitoring off in emby would that stop the errors in the log? I assume the scheduled task of scanning media library would continue working? Correct this error is from the filesystem exceeding the inotify set values. It only affects Real Time Monitoring and has no effect on Library scans. But is a easy fix provided above or here.
Carlo 4561 Posted October 17, 2021 Posted October 17, 2021 3 hours ago, Happy2Play said: But it is a platform/OS issue not a Emby issue. I guess in theory Emby could script update inotify for you but I don't believe Emby should be modifying system files like this. Agreed, Emby shouldn't be run as a user that has access to sudo type commands so it would be difficult to do because of permissions. Only a system admin should be making changes like this to the system, even though it's a trivial change.
FrostByte 5454 Posted October 17, 2021 Posted October 17, 2021 Maybe this should be in the kb? This seems to come up every week and we're always linking to an old thread for someone to sift through. There are a couple ways to fix it with me preferring to use a bootup task to change both values, but maybe cayars can use one with a little explanation of why/what. 1
Carlo 4561 Posted October 17, 2021 Posted October 17, 2021 (edited) I have been meaning to add this info to the KB. There seems to be a couple different ways to do this. For example you use the GUI to set this on startup and I tend to use a "sudo" command to make a permanent change. I seem to recall this working slightly different on a couple OSes as well but can't remember specifics right now. It probably wouldn't hurt to start a new thread to ask a few people to try changing this value using specific commands to make sure it sticks on restart to verify commands that work and keep updating the KB as we go. Gotta start somewhere. Edited October 17, 2021 by cayars 1
Happy2Play 9812 Posted October 17, 2021 Posted October 17, 2021 4 hours ago, cayars said: I have been meaning to add this info to the KB. Either KB or a Tutorials and Guides topic. 2
Carlo 4561 Posted October 17, 2021 Posted October 17, 2021 Probably better in the forum guide section is what I was thinking.
HawkXP71 112 Posted October 18, 2021 Author Posted October 18, 2021 On 10/16/2021 at 9:13 PM, cayars said: Agreed, Emby shouldn't be run as a user that has access to sudo type commands so it would be difficult to do because of permissions. Only a system admin should be making changes like this to the system, even though it's a trivial change. WHile Emby shouldnt be run as a admin normally, during setup it should be fine to have that level of permissions. I dont see why on install, it couldnt verify the value, and on startup log a message saying the message is too small.
Carlo 4561 Posted October 18, 2021 Posted October 18, 2021 Not possible to do on many OSes. For example part of DSM 7 update forbids this from taking place. That's why the user ends up having to do the migration vs our setup scripts (we tried).
HawkXP71 112 Posted October 22, 2021 Author Posted October 22, 2021 On 10/18/2021 at 8:50 AM, cayars said: Not possible to do on many OSes. For example part of DSM 7 update forbids this from taking place. That's why the user ends up having to do the migration vs our setup scripts (we tried). unfortunately that sucks.. Two possible suggestions to easy the issue. 1) In the log, for known issues like this, put a link to the knowledge base page. So if someone is reviewing their log and see an error that concerns them, they can simply click it, and learn how to fix the issue. 2) On the dashboard page, add a "Run a Checkup" button. When clicked, it would analyze the log files looking for known issues. Then list them with their likely solutions (or links to them).
HawkXP71 112 Posted October 26, 2021 Author Posted October 26, 2021 1 minute ago, Luke said: Has this helped you resolve this? Yes. Its fully resolved for me . Thanks for all your help 2
