BFCF 1 Posted September 6, 2014 Posted September 6, 2014 Hello! Is it possible to make Media Browser to auto-load the subtitles file when we select "Play to" function? Thanks!
Solution Beardyname 198 Posted September 7, 2014 Solution Posted September 7, 2014 I think the subtitles will depend on which user is used for DLNA and their specific settings ? aka if your user it set to enable subtitles depending on x and y it will respect that. (works for me at least ) 1
BFCF 1 Posted September 7, 2014 Author Posted September 7, 2014 (edited) I think the subtitles will depend on which user is used for DLNA and their specific settings ? aka if your user it set to enable subtitles depending on x and y it will respect that. (works for me at least ) That solved this issue for me! Thanks! BTW, can you help me here? Since you play your videos with subtitles? Edited September 7, 2014 by BFCF
Beardyname 198 Posted September 7, 2014 Posted September 7, 2014 That solved this issue for me! Thanks! BTW, can you help me here? Since you play your videos with subtitles? Already replied
