Disgustipated 0 Posted October 5, 2021 Posted October 5, 2021 I have the Emby app loaded on my Shield and MyClouPR4100. I installed this time yesterday and not all thumbnails are showing up. Is there a reason for this and can I manually fix it?
Disgustipated 0 Posted October 5, 2021 Author Posted October 5, 2021 3 minutes ago, Luke said: Hi there, how does the web app compare? Somewhat better but it's still not correct. Emby is also picking up remnants of media that I have long since deleted, even before I installed Emby.
ebr 16338 Posted October 5, 2021 Posted October 5, 2021 Hi. Those are two different screens in the two apps. What does the exact same view you showed in this app look like in the web app?
Disgustipated 0 Posted October 5, 2021 Author Posted October 5, 2021 21 minutes ago, ebr said: Hi. Those are two different screens in the two apps. What does the exact same view you showed in this app look like in the web app? Not sure why that matters as they were both from the same library but here's the same shot as the Shield app from the first post.
ebr 16338 Posted October 5, 2021 Posted October 5, 2021 Thank you. That allows me to see the exact same items and the images for them. It looks like you don't have primary images for the items that aren't showing in the TV app. The web appears to be falling back to backdrops in that instance. The TV app doesn't try to show backdrops for primary. What is the library type of this library? Something looks "off" as I see folders for some TV shows.
Happy2Play 9813 Posted October 5, 2021 Posted October 5, 2021 This does not look right from a TV library aspect. Can you verified the library content type on Dashboard-Library.
Disgustipated 0 Posted October 5, 2021 Author Posted October 5, 2021 2 hours ago, Happy2Play said: This does not look right from a TV library aspect. Can you verified the library content type on Dashboard-Library. 2 hours ago, ebr said: Thank you. That allows me to see the exact same items and the images for them. It looks like you don't have primary images for the items that aren't showing in the TV app. The web appears to be falling back to backdrops in that instance. The TV app doesn't try to show backdrops for primary. What is the library type of this library? Something looks "off" as I see folders for some TV shows. The library is "TV Shows" and the View is set to "Primary."
Happy2Play 9813 Posted October 5, 2021 Posted October 5, 2021 Just now, Disgustipated said: The library is "TV Shows" and the View is set to "Primary." As mentions then that would suggest Missing images for all these item. Do you save images with media? If so can you show the contents of the folder. If not then we will probably need to see a server log.
Disgustipated 0 Posted October 5, 2021 Author Posted October 5, 2021 2 minutes ago, Happy2Play said: As mentions then that would suggest Missing images for all these item. Do you save images with media? If so can you show the contents of the folder. If not then we will probably need to see a server log. No, I don't have all of the thumbnails for these items. I ASSumed the metadata, etc. would pick them up as with Plex, Kodi, and MrMC. I've attached the log for you. Thanks for working on this with me. Emby Server log 10.05.21.txt
ebr 16338 Posted October 5, 2021 Posted October 5, 2021 Hi. Did you follow our guidelines for the content structure? TV Naming It looks like some of your items are not being properly seen as TV series and then also not being identified so that you do get good metadata.
Happy2Play 9813 Posted October 5, 2021 Posted October 5, 2021 10 minutes ago, Disgustipated said: No, I don't have all of the thumbnails for these items. I ASSumed the metadata, etc. would pick them up as with Plex, Kodi, and MrMC. I've attached the log for you. Thanks for working on this with me. Emby Server log 10.05.21.txt 12.3 MB · 0 downloads Best guess right now would be permissions issues looking at this log example Quote System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/usr/share/ftp/4K_Movies_3/The Fifth Element (1997) 2160p.GBR.BluRay.HEVC.TrueHD.7.1.Atmos-AdBlue' is denied. You also have a issue with your Music path. 2021-10-05 09:37:09.910 Info LibraryMonitor: Skipping realtime monitor for smb://mycloudpr4100/music because the path does not exist SharpCifs.Smb.SmbException: SharpCifs.Smb.SmbException: Failed to connect: 192.168.1.136 But yes as ebr mentioned it could be orgainiation/naming. But would need to break it down for a specific example and log for that example.
Luke 42246 Posted October 6, 2021 Posted October 6, 2021 Is your media also stored on the same NAS as the server?
Disgustipated 0 Posted October 6, 2021 Author Posted October 6, 2021 4 hours ago, Luke said: Is your media also stored on the same NAS as the server? Yes, it is. 7 hours ago, ebr said: Hi. Did you follow our guidelines for the content structure? TV Naming It looks like some of your items are not being properly seen as TV series and then also not being identified so that you do get good metadata. I have it set properly sans the first air year. Foundation>Season 1> Foundation E01S01.mkv 7 hours ago, Happy2Play said: Best guess right now would be permissions issues looking at this log example You also have a issue with your Music path. 2021-10-05 09:37:09.910 Info LibraryMonitor: Skipping realtime monitor for smb://mycloudpr4100/music because the path does not exist SharpCifs.Smb.SmbException: SharpCifs.Smb.SmbException: Failed to connect: 192.168.1.136 But yes as ebr mentioned it could be orgainiation/naming. But would need to break it down for a specific example and log for that example. I fixed the MUSIC issue, thank you.
Luke 42246 Posted October 6, 2021 Posted October 6, 2021 Then why have you configured your libraries with smb network paths?
Disgustipated 0 Posted October 6, 2021 Author Posted October 6, 2021 2 hours ago, Luke said: Then why have you configured your libraries with smb network paths? I'm not following you. How should they be set up?
ebr 16338 Posted October 6, 2021 Posted October 6, 2021 42 minutes ago, Disgustipated said: I'm not following you. How should they be set up? Hi. You said they were on the same machine as the Emby server so you should be able to reference them with normal local paths.
Luke 42246 Posted October 7, 2021 Posted October 7, 2021 9 hours ago, Disgustipated said: I'm not following you. How should they be set up? What you setup the libraries in emby library setup, what folder paths did you enter?
Disgustipated 0 Posted October 7, 2021 Author Posted October 7, 2021 21 hours ago, ebr said: Hi. You said they were on the same machine as the Emby server so you should be able to reference them with normal local paths. 12 hours ago, Luke said: What you setup the libraries in emby library setup, what folder paths did you enter? I have them set-up like this. This is for TV SHOWS. I'm using a WDmyloudpr4100 as my server.
Luke 42246 Posted October 7, 2021 Posted October 7, 2021 OK then what is this path that we're seeing in the server log? smb://mycloudpr4100/music
Disgustipated 0 Posted October 7, 2021 Author Posted October 7, 2021 6 minutes ago, Luke said: OK then what is this path that we're seeing in the server log? smb://mycloudpr4100/music I've changed it to look like the rest /usr/share/ftp/MUSIC
Luke 42246 Posted October 8, 2021 Posted October 8, 2021 Are you still having an issue after doing that?
