TurtleXIII 0 Posted October 5, 2021 Posted October 5, 2021 For whatever reason when I try changing the image of a show/movie or something I just get a infinite loading animation and the image doesn't change. Any ideas?
Solution TurtleXIII 0 Posted October 5, 2021 Author Solution Posted October 5, 2021 Uhm well weird fix I guess. If I "Identify" an entry and make sure the "Replace images" is selected, then I can change the images after that easily...
Luke 42246 Posted October 5, 2021 Posted October 5, 2021 Hi there, if it happens again, let's look at an example: Thanks.
