sngreco 1 Posted October 5, 2021 Posted October 5, 2021 I just hooked up my HD Home Run and seems to be streaming perfectly, but I noticed all of the channels that are mapped using the built-in Emby guide are missing program data. The ones that were auto-mapped to my IPTV service work and show up just fine. I've refresh the guide multiple times, not sure what I'm missing here?
Carlo 4561 Posted October 5, 2021 Posted October 5, 2021 (edited) Hi, It looks like you have a mismatch going on. In the guide setup there is a check box at the bottom to use for all tuners. Unselect that. Now set the guide source for only the tuner it applies to. So the Emby Guide data for the HDHomeRun and the XML guide data only for the m3u. Then refresh your guide. Edited October 5, 2021 by cayars
