Gee1 10 Posted October 4, 2021 Posted October 4, 2021 Since a few days emby 4 Kodi -non next-gen- (4.1.22) dosnt work at all... whats the problem here?
Luke 42233 Posted October 4, 2021 Posted October 4, 2021 Hi there @Gee1 can you please describe your issue in more detail? Thanks.
Gee1 10 Posted October 9, 2021 Author Posted October 9, 2021 this issue is only on kodi 18.9 with emby non- next gen its an SSL issue i fixed it with: disable verify connection.. and it works again 1
quickmic 1709 Posted October 11, 2021 Posted October 11, 2021 On 10/10/2021 at 1:39 AM, Gee1 said: this issue is only on kodi 18.9 with emby non- next gen its an SSL issue i fixed it with: disable verify connection.. and it works again May I ask, why you don't use next-gen?
