CassTG 113 Posted October 3, 2021 Posted October 3, 2021 (edited) I presume the Samsung Tv's are susceptible to the LETSENCRYPT issue, as i got a warning today about incorrect Certs (my server is behind a proxy which has all new LE certs and no other devices of mine have issues connecting on port 443), it exited me from the app and now when i try to login via emby connect i can see the server in the list but when i click on it to connect i get the following warning message and then it goes back to server selection screen We're unable to connect to the selected server right now, please ensure it is running and try again Server is running fine on shield, browser, mobile and OSX app, just not via the Samsung TV app 1.0.94 Edited October 3, 2021 by CassTG
CassTG 113 Posted October 3, 2021 Author Posted October 3, 2021 Appears to be the LE issue, same happens on my older LG and my Mums new Samsung TV, cant even reinstall apps on the App Store as thats not working either Thank feck i use a shield lol
Luke 42241 Posted October 3, 2021 Posted October 3, 2021 Quote cant even reinstall apps on the App Store as thats not working either Ouch, hopefully Samsung gets on that quick.
CassTG 113 Posted October 3, 2021 Author Posted October 3, 2021 25 minutes ago, Luke said: Ouch, hopefully Samsung gets on that quick. Knowing Samsung it will be, we have an update for you, go but another new TV lol
shocker 135 Posted October 3, 2021 Posted October 3, 2021 Yes, this issue is the same one occurred with LG I've got the issue on both Samsung and LG. 1
SamES 1084 Posted October 3, 2021 Posted October 3, 2021 It looks like the LG users are having success moving to ZeroSSL which supports some older root certificates that are more likely to still be current in older TV's. https://emby.media/community/index.php?/topic/102144-several-lg-tvs-cannot-connect-to-server/&do=findComment&comment=1074180 2
CassTG 113 Posted October 5, 2021 Author Posted October 5, 2021 On 03/10/2021 at 23:28, SamES said: It looks like the LG users are having success moving to ZeroSSL which supports some older root certificates that are more likely to still be current in older TV's. https://emby.media/community/index.php?/topic/102144-several-lg-tvs-cannot-connect-to-server/&do=findComment&comment=1074180 Yep was taking a look at the Linuxserver Swag Docker and didnt realise they added support for ZeroSSL thought it was LE only, so rebuilt the container with the zerossl config and all is working properly again
achalmers 3 Posted October 10, 2021 Posted October 10, 2021 So I guess this is an issue with why my dads Samsung TV won't connect but all his other devices will. Im using HAproxy and Emby is behind the reverse proxy and using LetsEncrypt certificates. Anybody have a solution ?
CassTG 113 Posted October 11, 2021 Author Posted October 11, 2021 (edited) 23 hours ago, achalmers said: So I guess this is an issue with why my dads Samsung TV won't connect but all his other devices will. Im using HAproxy and Emby is behind the reverse proxy and using LetsEncrypt certificates. Anybody have a solution ? I dont use HAProxy but if they have the ability to switch to ZeroSSL certs instead of using LE (both use the same acme style challenge) then you issue is solved I use linuxserver's Swag docker which is the proxy/fail2ban/certbot and there docker just needed a env variable flag set to Zerossl. If however you import your cert into Haproxy then this is easier. Create a free account on zerossl site Add domain you want cert for It creates the cert Verify Ownership of domain Download and install certs Only issue with the above steps is the free account is limited to a single domain and you only get 3 free requests, whereas using the acme challenge option means wildcard and unlimited requests Edited October 11, 2021 by CassTG
