CassTG 113 Posted October 3, 2021 Posted October 3, 2021 Is there an issue with Emby Connect this afternoon I Normally use a shield which is no problem but was testing the Samsung Tv App, it was logged in but threw an error and exited. Tried to login via Emby COnnect PIN and the pin is accepted on the webpage, the spinning circle shows on the tv then it goes back to the Sign in with emby connect and no servers shown So i downloaded the Max OSX app to try there (the web page is working fine btw and so is the shield still) The OSX app requires username and password which i entered and it also just goes back to the sign in page and no server shown. The server 6.4.0 is up and running fine, can access from logged in devices like the web page and shield but no new logins are working they just boot you back to the sign in page. Running on a docker behind a proxy and the dashboard is showing the correct URL with port 443 which is correct
CassTG 113 Posted October 3, 2021 Author Posted October 3, 2021 Soz please ignore just checked user settings and my emby connect name was blank for some reason which was odd but all sorted
Carlo 4561 Posted October 3, 2021 Posted October 3, 2021 Hi, Are you setup on the Samsung to log directly into your Emby Server or are you using Emby Connect? I ask because the older Samsung are having a problem connecting to some website right now because of a change in certs done by Let's Encrypt. There are a lot of threads on the forum about this.
CassTG 113 Posted October 10, 2021 Author Posted October 10, 2021 Hi Yes sorry i found this issue and then raised the Lets Encrypt issue in a different thread, i switched the Swag Proxy docker by Linuxserver from Letsencrypt to ZeroSSL and eveything is fine on my devices, but found a weird issue which i will open a different thread for.
