kuebs 6 Posted September 6, 2014 Posted September 6, 2014 Hello, I have had a rough few days, and have been able to get my MB3 in working condition, but still have a lingering issue where I have to reinstall MB3 each time I reboot to start the server. That is in the server thread. My issue with CoverArt is that, it doesn't seem to be working. I have movies I just put into a new directory, which normally would pull data right away and coverart, but no Cover Art or pictures. MB3 has pulled the metadata and ROttenTomatoes has provided the reviews and summary and I have the actors info, but I do not get new cover art. Is there a way to force it to generate? I have the plugin installed. https://dl.dropboxusercontent.com/u/46573484/server-63545485501.txt https://dl.dropboxusercontent.com/u/46573484/server-63545536534.txt https://dl.dropboxusercontent.com/u/46573484/server-63545536741.txt
ebr 16344 Posted September 6, 2014 Posted September 6, 2014 First, a clarification - the CoverArt plug-in does not download any images. The normal system does that. CoverArt puts fancy covers or other treatments and additional information on the images you do have. Looking at your logs, it looks like the movies are simply not on tmdb. Most of the ones I saw actually looked like kids TV shows. Are you sure you shouldn't be defining these as TV?
kuebs 6 Posted September 8, 2014 Author Posted September 8, 2014 I am not worried about the kids show. I am worried about movies like, "Edge of Tomorrow". I still cannot get cover art for that.
ebr 16344 Posted September 8, 2014 Posted September 8, 2014 I am worried about movies like, "Edge of Tomorrow". I still cannot get cover art for that. No reference to that movie is in any of the logs you posted.
kuebs 6 Posted September 14, 2014 Author Posted September 14, 2014 That is odd. Because it is in Movies. It is not generating a cover image for it.
