matsonjr 6 Posted October 2, 2021 Posted October 2, 2021 First off, this is not an emby problem... I am having trouble with cetonproxy showing some channels, one being the Pac-12 network. If I use the VLC trick, all I get is a network error that says it can't open the channel. However, I can open and view this same channel in Windows Media Center and when I go the ceton device webpage to the channel that is tuned, it shows it is receiving the channel. Anyone have any ideas why cetonproxy isn't working with some channels?
Carlo 4561 Posted October 2, 2021 Posted October 2, 2021 Hi, If VLC won't play this channel but does play other channels this could be DRMed. WMC can handle DRM channels so it won't be a problem for it. I'm not really sure how to tell if it's DRM with the Cenon tuner. I can't remember if WMC will show you this info or not as it's been a long time since I've used it. If you want to PM me your zip/postal code and cable provider I can see if I can find out anything. Tell me the specific channel number as well.
