lestho 0 Posted October 2, 2021 Posted October 2, 2021 Hallo! Gibt es bei Emby die Möglichkeit, dass über http-Befehle auf Play, Pause geschaltet werden kann, oder dass mit einem http String andere Alben auf einem bestimmten Player gestartet wird. Beim Logitech Musik Server schaute so ein Befehl z.B. so aus: "http://IPADRESS:9002/status.html?p0=play&player=d4%3A3d%3A7e%3A92%3A93%3A81".... Hintergrund: Per Hausautomation den Player starten und Stoppen, also so wie "Webhooks" nur anders rum, wenn ich einen Raum (z.B. das Bad betrete, soll die Musik an gehen) Besten Dank!
Carlo 4561 Posted October 3, 2021 Posted October 3, 2021 Hi, Emby supports webhooks. We support Alexa and Google Home as well as some home automation setups. Have you taken a look at the plugin catalog to see if there is something ready to use for your system?
lestho 0 Posted October 4, 2021 Author Posted October 4, 2021 Hi! i need the other direction fron the webhooks. I want play and stop the musik over get http.... I havent alexa an co....
Luke 42239 Posted October 4, 2021 Posted October 4, 2021 13 hours ago, lestho said: Hi! i need the other direction fron the webhooks. I want play and stop the musik over get http.... I havent alexa an co.... Hi, if you'd like to remote control I would suggest exploring the Emby Server API: https://github.com/MediaBrowser/Emby/wiki 1
Carlo 4561 Posted October 5, 2021 Posted October 5, 2021 Yes and try this as well. From the Dashboard view scroll all the way to bottom. There you will see a Github link to the documentation as Luke showed but also is an API that uses swagger that you can test calls to your server with.
Painkiller88 250 Posted October 12, 2021 Posted October 12, 2021 On 10/4/2021 at 12:44 AM, cayars said: We support Alexa and Google Home as well as some home automation setups. How can i use Alexa? I am also from Germany/Austria and i haven't found a way to use Alexa. Thanks
Carlo 4561 Posted October 12, 2021 Posted October 12, 2021 https://support.emby.media/support/solutions/articles/44001160798-amazon-alexa Emby skill is available for the US, UK, Canada, Australia & India. German & French languages will be coming soon. I'm not sure exactly which countries are currently support for Google Home but it's probably similar. 1
Teddyknuddel 136 Posted May 20, 2023 Posted May 20, 2023 @LukeHier hieß es doch schon mal, kommt bald - ist jetzt auch schon 1,5 Jahre her. Getan hat sich seither NICHTS! On 10/12/2021 at 9:36 AM, Carlo said: German & French languages will be coming soon.
Luke 42239 Posted December 28, 2023 Posted December 28, 2023 On 10/3/2021 at 6:44 PM, Carlo said: Hi, Emby supports webhooks. We support Alexa and Google Home as well as some home automation setups. Have you taken a look at the plugin catalog to see if there is something ready to use for your system? Two new projects have been added in OneSky under Emby Server: EmbyHome EmbyHome-Alexa These string sets are used for both Google Home and Alexa. If you can help translate those then we can support more languages on those platforms. Thanks everyone.
Teddyknuddel 136 Posted December 28, 2023 Posted December 28, 2023 3 hours ago, Luke said: Zwei neue Projekte wurden in OneSky unter Emby Server hinzugefügt: EmbyHome EmbyHome-Alexa Diese Zeichenfolgensätze werden sowohl für Google Home als auch für Alexa verwendet. Wenn Sie bei der Übersetzung helfen können, können wir weitere Sprachen auf diesen Plattformen unterstützen. Vielen Dank an alle. OneSky?
GrimReaper 4895 Posted December 28, 2023 Posted December 28, 2023 8 minutes ago, Teddyknuddel said: OneSky?
Painkiller88 250 Posted December 28, 2023 Posted December 28, 2023 9 hours ago, Teddyknuddel said: OneSky? ja genau, man hat wohl die alten bereits übersetzten Sachen nicht übernommen und hat nun neue Projekte gemacht http://oshotim.oneskyapp.com/collaboration/translate/project/project/192956/language/6#/
