barkietrin7 0 Posted October 2, 2021 Posted October 2, 2021 I've installed the official Emby plugin on my FreeNAS host, and I've created a mount point to connect the Emby jail to the dataset containing my media. However, whatever folder I set as the destination for the mount point disappears from the list of folders to choose from when I log into the emby interface and attempt to create a library. If I set the Emby library folder, then go back and change the freenas jail mount point to that folder, the Emby library shows no media in the folder.
Happy2Play 9802 Posted October 7, 2021 Posted October 7, 2021 (edited) @Abobader Do you know why this quote injected spam links? But will guess something with this user as their other topic has links also. Edited October 7, 2021 by Happy2Play
Luke 42197 Posted October 19, 2021 Posted October 19, 2021 @barkietrin7 are you still having an issue with this?
