kyleh195 0 Posted October 1, 2021 Posted October 1, 2021 I am trying to load a m3u source of publicly available PBS stations from https://i.mjh.nz/PBS/all.m3u8 . I am able to load that url directly in VLC and it resolves and displays fine. When I loaded into VLC as an m3u tuner and loaded guide data from https://i.mjh.nz/PBS/all.xml it found the channels and related guide fine. However when I try to open the channel in emby it gives the following error "Playback Error - No compatible streams are currently available. Please try again later or contact your system administrator for details." I have logs of the activity but I can't fully make sense of what is failing. It seems like when loading the channel it tries to open the specific stream and ffprobe suceeds (ProcessRun 'ffprobe' Process exited with code 0) but then something fails further in the process of trancoding/streaming. To torubleshoot I loaded up xTeVe on the server and loaded the https://i.mjh.nz/PBS/all.m3u8 and same xml guide successfully there. The resulting xTeVe m3u stream loads fine in VLC but still fails in Emby.
Luke 42242 Posted October 1, 2021 Posted October 1, 2021 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
kyleh195 0 Posted October 2, 2021 Author Posted October 2, 2021 Relevant screenshots and logs emby log extract.txt ffmpeg-transcode-df09b442-6109-42ce-84ea-d128485bb1f9_1.txt
Carlo 4561 Posted October 2, 2021 Posted October 2, 2021 That channel plays fine for me What I'd suggest is removing xteve from the setup and add the channel and epg directly in Emby and try again.
kyleh195 0 Posted October 2, 2021 Author Posted October 2, 2021 Tried loading directly the first time, but it failed so I added in xTeVe to see if limiting the number of available channels would fix. Here are logs and info from trying to do it directly. It is still erroring out. I'm not sure if its relevant, but after clicking to play the channel once I see 3 ffmpeg logs, which are all attached. Not sure if there is a transcoding issue that is causing the multiple tries and ultimately the failure? Like I said it is processing in both scenarios in VLC, so the computer is able to handle the stream just not Emby. ffmpeg-transcode-5a761ef0-4ef5-4ef0-84c1-5254b7a0eed0_1.txt ffmpeg-transcode-2e4ac23e-73a3-4727-bf95-9a73735f9723_1.txt ffmpeg-directstream-141b491d-dfc8-4c5c-a7d3-86cafab7220e_1.txt embyserver - direct try.txt
Carlo 4561 Posted October 3, 2021 Posted October 3, 2021 (edited) @Luke Can you take a look at this and tell us what you think is going on? Looks like it's trying to cycle through the streams in the M3U. Edited October 4, 2021 by cayars
Luke 42242 Posted October 7, 2021 Posted October 7, 2021 Hi, yes I'm not quite sure of the problem as it's happening within ffmpeg. The upcoming Emby Server 4.7 will be updating to a newer ffmpeg build so there's a decent chance that will help with this. 1
yarafie 6 Posted October 7, 2021 Posted October 7, 2021 I'm using server 4.7.0.13 on a Nvidia Shield TV Pro 2019 and the playlist mentioned above works fine for me.
millie92 2 Posted March 6, 2023 Posted March 6, 2023 i used this m3u before with vlc for watching pbs with my bf. but this time visiting its not working anymore so i make a new solution. now we can watch again so she very happy. i can share it if someone is needing also
Luke 42242 Posted March 6, 2023 Posted March 6, 2023 2 minutes ago, millie92 said: i used this m3u before with vlc for watching pbs with my bf. but this time visiting its not working anymore so i make a new solution. now we can watch again so she very happy. i can share it if someone is needing also Hi, what is the solution?
millie92 2 Posted March 6, 2023 Posted March 6, 2023 20 minutes ago, millie92 said: with my bf LOL i typo mean GF. she not happy if she saw it lmao 18 minutes ago, Luke said: Hi, what is the solution? i try to make it easy: docker run -d -p 7777:7777 ghcr.io/miibeez/vlc-bridge-pbs vlc http://localhost:7777/pbs/playlist.m3u
