tcichowicz 4 Posted October 1, 2021 Posted October 1, 2021 I run two Synology devices DS1520+. Both have separate EMBY servers running 4.6.4.0 One is working fine, (NAS2) the other (NAS3) has not been updating the DB ... But run against their own volumes for the content, but the content is sync'd between the two. I've tried removing all the libraries from the Libray interface and restoring from a backup, that didn't do anything to correct the problem. I then removed all the libries again and the recreated them manually from scratch. That also didn't do anything. I wanted to delete the library.db files but can't find the path location on the synology. I checked the logs to see if I can find a location there as some post I've found say that's where the path would be found. Can anyone help?
Carlo 4561 Posted October 1, 2021 Posted October 1, 2021 Hi, do us a favor and post your server log from the NAS3 box and let us take a look.
tcichowicz 4 Posted October 1, 2021 Author Posted October 1, 2021 embyserver.txt I also noticed it seems to be ONLY my Movies Library - I just added a New TV show - and that appeared as it should..
Happy2Play 9812 Posted October 1, 2021 Posted October 1, 2021 You have access denied om libraries and can not find on movie library System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/volume1/_media/music/Air Supply' is denied. System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/volume1/_media/tv_shows_archive/Gilligan's Island' is denied. System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/volume1/_media/tv_shows/Nine Perfect Strangers/Season 1' is denied. System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/volume1/_media/movies/A Dog's Journey (2019)'. Would first look at permissions across all media. 1
tcichowicz 4 Posted October 1, 2021 Author Posted October 1, 2021 OK... I assume I need to check and or change that Within the Shared Folder... the '_media' share is the parent to all my content library folders.
Happy2Play 9812 Posted October 1, 2021 Posted October 1, 2021 @cayarsShould permissions be on Internal User not Local Users? 1
Carlo 4561 Posted October 2, 2021 Posted October 2, 2021 Yes System Internal Users dropdown and then emby.,
FrostByte 5454 Posted October 2, 2021 Posted October 2, 2021 The topic says he's on DSM 6 though which is a local user.
Happy2Play 9812 Posted October 2, 2021 Posted October 2, 2021 17 minutes ago, FrostByte said: The topic says he's on DSM 6 though which is a local user. Do you have any ideas as the log shows access denied and Could not find a part of the path?
FrostByte 5454 Posted October 2, 2021 Posted October 2, 2021 I'm not seeing it right now. Possible folder/file permissions and not shared folder.
tcichowicz 4 Posted October 2, 2021 Author Posted October 2, 2021 I’ve compared those settings to my other working NAS2, they are exactly the same including internal users… ‘Emby’ not listed as an internal user on either of my systems. 1
tcichowicz 4 Posted October 2, 2021 Author Posted October 2, 2021 OK, so back to one of my questions... what is the path to my library.db files?
Carlo 4561 Posted October 2, 2021 Posted October 2, 2021 This shouldn't have anything to do with the library.db file or it's permissions. The location is likely /volume1/Emby/data/library.db but it could be different The problem seems to be permission related on /volume1/_media/ and folders under it. If you like, send me a PM and we can do a remote support session. I'm sure I can help you get this fixed. PS: goto the Network menu in Emby web admin and turn off the item "Enable automatic port mapping" as it's not needed on your system. Emby keeps trying to do the port mapping and is flooding your logs with errors making it hard to read.
tcichowicz 4 Posted October 2, 2021 Author Posted October 2, 2021 thanks... I turned off auto port mapping. also PM'd u.
Solution tcichowicz 4 Posted October 3, 2021 Author Solution Posted October 3, 2021 cayars; Thanks so much for 'Remoting in' and fixing my issue! You showed me where I needed to change the file permissions within the File Station - to change the permissions to all the child folders and files of the parent Shared Folder. Thanks again!! 2
Carlo 4561 Posted October 3, 2021 Posted October 3, 2021 6 hours ago, tcichowicz said: Thanks so much for 'Remoting in' and fixing my issue! You showed me where I needed to change the file permissions within the File Station - to change the permissions to all the child folders and files of the parent Shared Folder. If it makes you feel any better I've helped two other people remotely since you with the same issue! Deja Vu for me. 2
